Ground question
Old Feb 9, 2022 | 11:08 AM
61Redneck's Avatar
61Redneck
Ground question
Where is the frame to body ground on a 61 f100?
Old Feb 9, 2022 | 12:08 PM
Sortofa65's Avatar
Sortofa65
My 65' is completely apart there were no grounds attached anywhere independent of what may be in a wiring harness and the main battery to engine ground. Everything did work before I took it apart.
Old Feb 9, 2022 | 12:38 PM
Crop Duster's Avatar
Crop Duster
Ground the engine to the frame and to the cab and you're done.
Old Feb 9, 2022 | 01:47 PM
dubya TF's Avatar
dubya TF
I welded a stud to my frame in two places. 1 directly under the battery for the negative cable and 1 at the rear of the block below the heater core for my body and engine ground straps.
Old Feb 9, 2022 | 03:06 PM
61Redneck's Avatar
61Redneck
Also, do these trucks have a fuse board?
Old Feb 9, 2022 | 03:46 PM
Tom H So. Ca.'s Avatar
Tom H So. Ca.
Under the dash attached to the lighting switch.
Tom
Old Feb 10, 2022 | 05:41 AM
lizardman1's Avatar
lizardman1
I have the battery, engine and core support grounded directly to the frame, the firewall is grounded to the engine.
Old Feb 11, 2022 | 04:16 PM
Thunderkiss1965's Avatar
Thunderkiss1965
I have grounds from; battery to block battery to core support, frame to block, firewall to block dashboard instrument panel to firewall, where it goes to block. Hood to fender to frame, bed to frame... I think that's it. Kind of overkill but I got a deal on a spool of braided copper wire on Amazon.
Ding126
Oct 25, 2020 05:34 AM
Magnus E
Oct 8, 2019 02:31 PM
Eric H
Sep 26, 2009 06:10 PM
2classics
Offroad & 4x4
May 14, 2008 07:16 PM
