Wanted to know how you ground the accessories you have installed such as lighting. The truck manual says not to used the battery as a ground.
I assume you used the body or frame.
Looking for ideas since Im electrically illiterate
Thank you
On every accessory I've put on I run a ground to the nearest existing ground wire I can find on the frame. I'll ring lug the wire with a connecter big enough to go around the bolt and just place it directly on top of the factory ground wire.
