brake shield gasket?
Old Dec 6, 2017 | 07:48 PM
pmason0's Avatar
pmason0
Bought and striped a 1973 F100 for the power disc brakes and other parts. Starting to disassemble the parts for cleaning/painting them.
When I took the brake shields off the spindles I found this round gasket between the shield and spindle.
None of the parts diagrams seem to show this gasket, to get new ones once I put everything back together.
Ideas? Identification?
Thanks
Old Dec 6, 2017 | 08:40 PM
TA455HO's Avatar
TA455HO
Lead Gopher
This must be it here circled in red.
D3TZ-2B160-A - Gasket
Chad
Old Dec 7, 2017 | 07:13 AM
pmason0's Avatar
pmason0
Chad,
Thanks for the quick reply and research. Doing some searching I have not been able to find that part, but I have found E2TZ-2B160-B which close I think but its for a mid 2000 E250 at TascaParts.com. Anyone buy something from them? Figured $3.33 its worth a try.
Old Dec 7, 2017 | 07:24 AM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Originally Posted by pmason0
Chad,
PartsVoice says Bob Allen Ford Overland Park, KS 66212 has 4 913-381-3000
Old Dec 7, 2017 | 08:04 AM
pmason0's Avatar
pmason0
JRJ, Thanks for the tip, just called Bob Allens Ford and they checked, but didn't have any and said there database showed no one did.
I guess I could always make one they seem like paper/felt.
Old Dec 7, 2017 | 01:30 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Thanks for the quick reply and research. Doing some searching I have not been able to find that part, but...
E2TZ-2B160-B used with dual piston calipers for 1982 and later E250 & F250's over 6,900 lbs. E350 & F350 and 1988 and later F (Super Duty).
Old Feb 12, 2022 | 12:38 AM
Wrenchin Wench's Avatar
Wrenchin Wench
2nd Gear
Relatable
I tried to put mine back together with some gasket maker as mine was stretched out and torn and had some obvious spots missing. I couldn’t find anyone that knew what the hell it was or where to get a new one. I remember the big name spots used to carry sheets of the same material and you would cut to your specs. But no more. However I found this today.
Dana Spicer Axle Shaft Shield
picking one up tomorrow so we shall see🤷🏻‍♀️
Paramorpheus
Sep 3, 2018 07:49 PM
OrangeBeast
Apr 2, 2018 11:59 PM
mikeinri
Jun 6, 2015 12:25 PM
1964Goat
Feb 22, 2012 04:58 AM
