1978 - 1996 Big Bronco
1990 bronco engine swap
Old Feb 21, 2022 | 08:09 PM
  #31
frankiethethumper's Avatar
frankiethethumper
I've been trying to dig a little deeper into compatibility issues with the 5.0 to 5.8 swap. If I understood Conanski's comment correctly, my current 5 spd transmission should mate fine with a similar year 5.8 motor as long as I get a flywheel/clutch suited for the 5.8 vs the 5.0. That sounds relatively easy to me, but am I missing something?
Also, I'm seeing some F250s for sale with 5.8 that could serve as a potential donor vehicle. Some of them have a 5spd manual transmission. Does anyone know if the 5spd in a heavy duty truck would be different than what came in my Bronco?
Old Feb 21, 2022 | 09:01 PM
  #32
Conanski's Avatar
Conanski
Engine balance is different between the two motors so the flywheels are identical except for the counterbalance weight built into it, but that is enough to require a different flywheel and yes it's that easy.
Yes the trans is different in the HD trucks, they got a ZF5 gearbox with a granny low 1st gear and an optional PTO while your truck has a Mazda 5sp. The ZF is better for HD uses but is a bit clunky to use, while the M5OD is better for driving around.
Old Feb 22, 2022 | 07:19 PM
  #33
frankiethethumper
I really appreciate clarification on all of this.
infantrycolo
Feb 16, 2011 11:27 PM
BaronVonAutomatc
Jan 21, 2008 05:25 PM
PTownBronco
Apr 28, 2006 06:54 AM
ShawnZ
Engine Swaps
Jul 16, 2004 11:32 PM
71BroncoJoe
Sep 28, 2002 07:30 AM
