busted transfer case
Ive been looking it up, the cause, but still not sure what happened.
I think my hubs might have been stuck in locked?
This happened going over Hwy 17 in 2 wheel drive. (supposedly)
Coincidently we had to use 4wd to get out of the mud in the morning...
I haven't used 4wd in about a year! I changed the fluid just before that.
I also had to use a wrench to turn the hubs, which is why I figure they might be stuck.
So my rig is a 2000 f450 4x4.
I love the truck and want to fix it.
Biggest question I have is how hard to swap an input shaft?
Im guess mine is a 24t and all the units for sale are usually different...
I was also wondering if f450/550 are the same np271 as f250?
I will need to replace front driveline as well.
It was rotating after the driveline broke apparently, and was being held up by crossmember while still rolling.
So now it has a big ol circle indent.
Thanks for the help!
https://www.ford-trucks.com/forums/1...st-peachy.html
I felt a vibration start under my butt and it quickly escalated to the point where I could not pull over to the shoulder fast enough to prevent catastrophic damage. Like you, I think my hubs were stuck locked despite the **** being in the unlocked position. Mine are Warn manual lockers though.
What input shaft are you wanting to swap in? With a tcase cracked open like that, your only option is full replacement. I highly recommend getting the front driveshaft rebuilt and balanced too.
Im still unsure why it ACTUALLY blew up.
I have manual hubs and have definitely drove it in 4wd high, on road, for short distances, with no probs.
I heard something about the front driveshaft slip binding?
After it blew up I called AAA.
They couldn't tow it right away and I was pulling a trailer,
so I actually ended up driving it 30 miles home and it drove perfect!
I couldn't believe it.
Its parked for good now tho.
So do you think my input shaft should be replace not swapped?
Im guessing yes...
I will replace or rebuild front driveshaft and hubs as well.
I have a zf6 so all signs point to 24t.
I guess the outputs are all the same?
So I was thinking I will grab a used transfer case and rebuild it.
Maybe I will wait for a 24t np271 to pop up, but seems unlikely.
Thanks again!
Im guessing yes...
Thanks again!
You’re right. It doesn’t. An unbalanced driveshaft getting spun does.
Your ZF6 t-case has a different input shaft than 4R100’s have. (It’s the same as 5R110 *I think*. Swapping the input shaft and resealing the t-case isn’t that difficult if you don’t find the correct t-case.
https://www.ford-trucks.com/forums/1...e-curious.html
It looks like you have a new TC acquisition course of action set out already, but if you need to purchase a refurbished TC, All Star is a good source for that sort of thing. Link: https://www.allstarstandardtransmission.com/
Good luck and keep us updated!
