Sponsored by: Auxito
Vss pulses question
Old Feb 4, 2022 | 03:52 PM
Squirrelnato40's Avatar
Squirrelnato40
Vss pulses question
Hey yall. I have a 1996 f150 300 inline e40d. Swapped body with a 1950 f1. Making a rat rod project. Recently got a cluster out of a 2006. Before I chop up my harness trying to make this work. I need to find out if gague has same VSS pulses. Any know know how I can look this up
Old Feb 5, 2022 | 09:47 AM
projectSHO89's Avatar
projectSHO89
In its original configuration, the '06 cluster gets the VSS data from the PCM via a network message, not directly from a sensor (which actually goes to the PCM).
Old Feb 7, 2022 | 08:11 AM
manicmechanic007's Avatar
manicmechanic007
True story it might not just work
However it is worth a try
The signals are the same I believe
The VSS was a voltage generator and I believe the newer ones on the trans output shafts work the same way
I have not looked at a speed sensor PID on a 06 lately to know what is outputted (ac milli voltage or just a hall effect square wave signal)
Worst case it will burn up the speedo in the 06 cluster
Old Feb 7, 2022 | 09:53 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Nope. The VSS generates a square wave. The PCM reads the up/down change in voltage, it does not read the actual voltage in the circuit.
Old Feb 7, 2022 | 10:35 AM
projectSHO89
Reminder that the OP's "rat rod" project is a 1996 truck with an E4OD. He's wanting to incorporate a cluster from two generations post manufacture of the original truck. I doubt that the transmission's output sensors would be pertinent given the shift in the technology involved (cluster has no way of utilizing the the transmission sensors' signals directly).
I'm just seeing no way to do it without a LOT of re-engineering that would require an intimate and extensive amount of knowledge of how the newer cluster operates and might be adapted.
Victory2909
Jan 26, 2012 10:38 AM
byron2003
2004 - 2008 F150
19
Sep 5, 2011 12:31 PM
burninfilm
Dec 18, 2008 05:16 PM
MonatheGrona94
Nov 29, 2006 11:20 AM
chazglenn3
Aug 18, 2006 09:37 AM
