Stripped trans pan drain threads
Old Feb 3, 2022 | 11:15 AM
Johnny Merck's Avatar
Johnny Merck
Hey guys,
chnged my tranny fluid and stripped out the thread on the trans pan putting the plug back in it. Anyone have a good method for re thread with a bigger bolt or using a helicoil or another successful method?
appreciate the input. Thanks
Old Feb 3, 2022 | 01:49 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
What trans?
AOD/E/70W pan all interchange, I think the aftermarket one I picked up for the '01 Lobo was $30 with a drain plug as the OE did not have a drain plug. The E4OD/4R100 are the same and seems all 4R have a drain pan from me nosing around. Not sure on the C6, but the few OE pans I have seen had no plug.
I suppose you could clean the pan, weld a nut and go larger too. Depends how much time you have to spend. I guess you could even hold the nut in the pan and tighten the drain plug at the same time to get on the road quick.
Old Feb 4, 2022 | 05:43 PM
94ZR580's Avatar
94ZR580
Do they make oversize plugs like they do for oil pans? 1, 2, & 3 OS. They oil pans plugs have self tapping threads.
mizzitch
Nov 24, 2024 05:20 PM
L-ight
20
May 21, 2018 03:49 PM
fludoc
Jun 14, 2008 06:47 AM
ThatGuy Dan
Jul 24, 2005 03:51 PM
z 97ford1
1997 - 2003 F150
Oct 15, 2003 11:43 AM
