trans fluid change
Old Jul 21, 2005 | 10:39 AM
ThatGuy Dan's Avatar
ThatGuy Dan
trans fluid change
Hey all - I'm going to be changing out the trans fluid of my 84 E-150 and I wanted to know if there are any quirky things that might not be mentioned in my Haynes manual. I've never changed trans fluid before, but I figure it's simliar to oil..just with a little more bolts involved.
Thanks for the help!
ThatGuy Dan
Old Jul 21, 2005 | 10:59 AM
reno94's Avatar
reno94
There is a drain plug in the torque converter that can be accessed by removing a small tin plate between engine oil pan and trans housing , you may need to rotate the converter to get the plug to the bottom, but by doing this you change almost all the trans oil vs just a few quarts by only dropping the pan.
Old Jul 21, 2005 | 12:27 PM
IceWagon's Avatar
IceWagon
the quirky part is not making a mess. since the stock trans pan doesn't have a drain screw, you need to loosten the screws in a sequence so that the trans oil will drain from one side of the pan. Even though the manuals describe this, it never works for me. So once I get the pan off, I buy a transmission drain kit, so I can drain the fluid much easier. This is especially handy if the tranny is overfilled and you need to get just one pint out. You have to drill a hole in your existing trans pan and bolt in a plug with a plug. They work great.
Since you are going this far, inspect your trans filter. If the filter is clean you can just put it back with a new gasket.
Finally don't overtighten the oil pan bolts. The pan is is soft and distorts easily. If the trans fluid has never been changed before you will find a dust plug with an oring on it, in the pan. Just throw it away.
Old Jul 21, 2005 | 12:55 PM
Casey's Avatar
Casey
You could also use this procedure:
CLICK HERE
Old Jul 21, 2005 | 01:39 PM
Bear River's Avatar
Bear River
Former ******
Also, while you are there, make sure you replace the tranny filter.
Old Jul 24, 2005 | 03:51 PM
Cor's Avatar
Cor
Originally Posted by IceWagon
the quirky part is not making a mess. since the stock trans pan doesn't have a drain screw, .......
I have used a piece of 3/8 nylon brakepipe (airline for truckbrakes, is a bit stiffer than pvc) and an inexpensive gearpump from the hardware store, mounted on the drill.
Use a piece 1-2 ft longer than your tranny dipstick, and prime this with fresh fluid before inserting this in the dipsticktube.
Works great to drain most of the oil from the pan, then the pan comes off without making a mess.
Cor
That_Guy
Aug 15, 2009 11:56 AM
That_Guy
22
Jul 11, 2008 03:54 PM
That_Guy
23
Mar 22, 2008 02:30 PM
That_Guy
22
Dec 28, 2007 06:45 AM
99F150
Oil & Lubrication
18
Dec 30, 2004 12:57 AM
