I screwed up by not paying attention. Oil change.
So long story short I drained out the trans fluid and added 13 qrts to the crankcase. Saw it was over filled so went back and drained the same pan lol. I then realized I removed the wrong plug. It was the damn trans pan and realized the oil pan was further up. So drained out all the oil from the oil pan. Now I need to refill the trans. This is where I am asking you guys. Do I just refill with what I drained out? Do. I need to remove the pan? Do I need to replace the trans filter too? Truck has 89k miles. Trans fluid never been replaced that I know of. It was my dad's that I purchased from him. He is looking now for all the paper work to see if the trans fluid/filter has been replaced before.
Also the pan only drained maybe three quarts, if that.
Thanks for the quick replies man.
I just talked with my dad and he had it done roughly 2 years ago
So you said Mercon V but I'm reading my truck takes MERCON only? I just filled the trans up with mercon V. I hope this isn't wrong? Truck is in Sig.
Ford really should have just renamed Mercon to Mercon 2.0 to avoid the confusion this caused (and is still causing) when they issued the TSB back in 2006, changing the fluid.
Stewart
Ford superseded the Mercon when they had Mercon V reformulated and it is now the proper trans fluid for the 4R100.
Stewart
Stewart
It is admirable that you admitted your mistake. Not enough people do that these days.
I had a pretty big "oops" on a dodge cummins I once owned. I intended to suck out and refill the power steering fluid, not knowing the last time it was done. I mistakenly sucked out the brake fluid and filled the brake fluid resevoir with atf +4, which is the proper fluid for that generation power steering in the dodges.
It was weeks later, when I went in for an airbag recall, the service writer pointed out the brake fluid reservoir, trying to sell me a brake fluid flush. I bit my tongue, politely declined, and flushed the brake fluid myself when I got home that day. Luckily, I only had about 75 miles on that mistake, thanks to my little Saturn commuter car, and the atf stayed in the resevior and didn't get circulated. I got lucky. I drive 500+ miles a week and it had been around 3 weeks. Had I driven the 1500+ miles on that truck with atf in the braking system, it would have gotten expensive quick. Nothing bad came of it, but it could have ended horribly.
I also almost drained the tranny fluid in my current truck, instead of the oil. A quick 2nd look as the wrench was on the trans drain bolt, saved my wallet.
Damn that would have been a big money pit if the atf starting circulating through the abs system. Good thing you caught that.
Years ago I bought a 2004 Audi S4 new from the factory. My first oil change I was talking to another person in the bay at the on base Auto Hobby Shop. I ended up emptying the from differential oil out instead of the engine oil. I had to have the car flatbed towed 40 miles away to the Audi dealer so they could put new fluid in the front differential for me.
Embarrassing as it was, I learned a lesson that day.
Things happen, how we recover from them or learn from them is what really matters.
