The 2022s use the same filter as the previous trucks? Just want to make sure I order the correct one. $37 on Amazon right now.
BE CAREFUL!!!
The $37 filter sets I saw on amazon were FAKE CHEAP CHINESE JUNK!!!
Says oem, but doesn't say Ford or Motorcraft, buyer beware.
Use only OEM Motorcraft. FD4625AA, about $60 on amazon today.
I got mine for $52/set from dieselfiltersonline.com, however, you will need to rack up your cart to get free shipping. May be a good time to pick up a couple of sets of fuel filters and oil filters all at once...
BE CAREFUL!!!
Thanks for the tip! It says OEM, so I figured it must be. I'll take another look.
I did just like I saw one guy do on a video, and that was to start the primary filter draining, and while it was, go up top and do the secondary filter change, then go back and change the primary. Worked out great, and all I did was do about 6 priming cycles of 25 seconds each, and it fired right up with no issues at all with any air in the system.
I did the same.Pretty straightforward.What I DIDN'T do is plug the little sensor back in underneath when I was done,to which my WIF alert reminded me of the very next morning.I knew immediately what it was.
