First Fuel Filter Change Done...
Old Jan 27, 2022 | 04:15 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Not too bad I guess, about 35-40 minutes this first time, should be able to get that down to about 20-25 as I get used to doing it.
Would have let the Quick Lane do it, but they want like $250, IIRC, way too high.
Filter set was $54 on amazon, had them for a couple of months now, so they probably went up.
But, still saved almost $200 doing it myself.
It was easier on my last PowerStroke, back in 2012!
And, on the difficulty meter, was about even with changing them on my old 2015 RAM Cummins.
Old Jan 27, 2022 | 06:35 PM
2019er's Avatar
2019er
You change your fuel filters like a girl... heheheh.
$250 is outright thievery. Even I do my own, and mine's a Platinum.
Old Jan 28, 2022 | 04:25 AM
B-ManFX4's Avatar
B-ManFX4
Is a Platinum fuel filter change somehow different than any other?
Old Jan 28, 2022 | 06:59 AM
DaveyMac's Avatar
DaveyMac
Why, Is it that some report when draining filter, some get more fuel out (gallons) than others (a gallon or less )?
Old Jan 28, 2022 | 07:49 AM
BSHORT's Avatar
BSHORT
Top Answer: 5
Wife's little Colorado diesel is the easiest I've seen to replace. I'll post a video that shows the location. (The guy in the video is making a huge mess and took way longer than necessary).
The 6.6 Duramax was a pain in the butt to change.
Old Jan 28, 2022 | 08:08 AM
2019er's Avatar
2019er
haha, no, but some people get the impression platinum owners might be to fru fru to do something :-). Maybe not here.
To be helpful, other threads have said to have an extra one or two of the yellow plastic clips on hand, since they might break. So far, mine haven't.
scraprat's Avatar
scraprat
Top Answer: 5
I don't know maybe it's just me but how hard is it to put some cardboard down and a tarp so all the mess is contained plus putting his hands down on the driveway and getting the dirt on the gloves that he's touching the new filters with. Plus were those nails laying on the driveway?
Old Jan 28, 2022 | 08:15 AM
riverratrusty's Avatar
riverratrusty
I have an amazon box that is the right height to get the drain pan close, allow we to access the plug and not get any drips, spalshed or anything else on the driveway. I'll be keeping that box, redneck engineering....
Old Jan 28, 2022 | 08:23 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
That's one of the things that bugs me for fuel filter changes, whether on this Ford or my previous RAM, was the fuel I was throwing away.
I used the same jug I used to drain the fuel from when I did filter changes on the RAM, a cut off plastic laundry soap jug, and it probably was about 2/3rds full, probably less than 1/2 a gallon. If I had some paint filters or something to use, I'd have poured it into my aux tank instead of on my tree limb burn pile.
I have no idea why anyone would get more fuel drained out than I did, that's all there was in the filter.
Old Jan 28, 2022 | 08:29 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
I have a small step stool that I used to set my drain jug on below the primary filter drain, didn't miss a drop of fuel, no mess at all.
Now, got fuel all over my hands and dribbled onto a couple of components underhood, even though I had a big bunch of paper towels under the secondary filter hose connections when I took them loose. Will have to do that better next time.
Old Jan 28, 2022 | 08:35 AM
ATC_F350's Avatar
ATC_F350
On thing my son taught me on the fuel filter changes;
is to change the bottom filter, then cycle key to prime and then start it, then proceed to do the top filter. This keeps you from having all the air of both filters in the system. I tend to get about a quart to a quart and a half of diesel from changes which goes to the burn fuel jug.
Old Jan 28, 2022 | 08:42 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
I did just like I saw one guy do on a video, and that was to start the primary filter draining, and while it was, go up top and do the secondary filter change, then go back and change the primary. Worked out great, and all I did was do about 6 priming cycles of 25 seconds each, and it fired right up with no issues at all with any air in the system.
Old Jan 29, 2022 | 09:08 AM
honda250xtitan's Avatar
honda250xtitan
hahaha underrated comment
Old Jan 29, 2022 | 09:26 AM
BillyE's Avatar
BillyE
I would expect any quick change place to botch it somehow
Old Jan 29, 2022 | 10:21 AM
HRTKD's Avatar
HRTKD
My independent diesel mechanic wanted just as much as Ford for the fuel filter change. I did have Ford do the first one because I had read that the top fuel filter connections sometimes break. I'll do the next one, but I'm not looking forward to it.
Supposedly some of the 2017 trucks like to drain a lot of fuel. I think I read that disconnecting the fuel line on top of the fuel tank is the solution.
