Fuel Filter Change interval
Old Nov 4, 2006 | 09:25 PM
Uzumati's Avatar
Uzumati
OK I need opinions. I have installed a Baldwin 1212 fuel filter pre pump and am planning on changing it at 6 month intervals (recommended 1year but I like overkill). Now as far as the OEM filter can it go this long?
Do I need to change the OEM Fuel filter:
1. When I change the Baldwn
2. Every other Baldwin Change
3. 10K like the manual states
4. Ditch the OEM and depend on the Baldwin
Old Nov 4, 2006 | 09:31 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
If the new Baldwin is finer filtering media than the stock engine-mounted filter, i see no real reason to change the stock filter other than it maybe decomposing. Fact is that if you have a finer filter before the main filter, all that is doing is causing a restriction to the fuel, and it's not filtering anything, because the fuel has already been strained cleaner than what the filter will stop. A possibility could be it stopping gunk that comes out of the pump, if that is possible. If you are doing a Regulated Return fuel system eventually, you could remove the filter bowl like i did. I would say change the baldwin filter every 15,000 miles and the engine mounted filter annually, if you like overkill.
Old Nov 4, 2006 | 09:36 PM
mueckster's Avatar
mueckster
I change my pre pump filter and the stock one at the same intervals ( about every 15k miles). No problems. Have been lucky and there has never been any water in my fuel, when drained. I cleaned the filter bowl when I got the truck at 43k miles and not found anything in it since.
Old Nov 4, 2006 | 09:39 PM
Uzumati's Avatar
Uzumati
I'll have to re-read but i think i remember the micron rating on the baldwin being half that of the OEM and thats kinda what i was thinking with option 4 is doing a reg return and elimiante the bowl or eliminate the filter in the bowl and just use it as a reservoir
