Heater core?
Old Jan 24, 2022 | 08:20 AM
moneymike's Avatar
moneymike
Heater core?
My heater core is leaking. 79 f100 custom 300, 3sp 2wd short bed. Napa says I have 2 options standard heat and high output. They are different sizes. I have not pulled mine yet to see, as I have been busy with my kids. Napa can only get high output as the standard is sold out nation wide. My question is are they interchangeable. Like if my truck was a standard will a high output fit?
Old Jan 24, 2022 | 08:54 AM
ranger140892's Avatar
ranger140892
Grumpy goat
I don't think they're interchangeable. My truck has high output heat. A long time ago, I changed the heater core and could only find a standard size core. It was smaller than my old one but fit. However, most of the forced air went around the heater core. There was almost no heat.
Old Jan 24, 2022 | 09:29 AM
ivsamhain's Avatar
ivsamhain
Here’s some rabbit holing
https://www.ford-trucks.com/forums/1...e-years-2.html
Old Jan 24, 2022 | 11:36 AM
meangreen92's Avatar
meangreen92
I think you want to source a heater core for a 1973 Mustang, or something like that. Number Dummy said that the truck High Output Heater is really just a Mustang heater box assembly - but I forget the exact year Mustang. And it's pretty safe to assume that the '71 and '72 Mustangs would be the same as well.
Old Jan 24, 2022 | 02:54 PM
Jack250's Avatar
Jack250
I have seen guys cut out the plastic piece that shortens the slot for the heater core. This allows the high output core to fit. My 76 F250 came with the high output heater and has it noted on the dash bezel.
Old Jan 24, 2022 | 03:22 PM
ranger140892
Grumpy goat
My old one was still good, so I reinstalled it. Only reason I wanted to replace it, was because I had the box out anyway. But I did find a correct new manufacture one. Cannot remember where I bought it.
Old Jan 24, 2022 | 06:22 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Rockauto shows having them available.
https://www.rockauto.com/en/catalog/...ater+core,6864
And, if needed, the standard heater housing can be modified to fit the HO heater core.
Old Jan 25, 2022 | 06:00 PM
lafermedavid's Avatar
lafermedavid
standard heat cor
Old Jan 28, 2022 | 09:42 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
That plastic provision can be removed in order to allow a hi output be installed in place of regular. It probably would work better anyway.
Doc_G
Aug 15, 2014 08:21 AM
hav24wheel
Jan 14, 2009 02:57 PM
Vinford
Oct 4, 2005 08:42 PM
don_79f250
Dec 13, 2004 07:32 PM
1976 ranger
Nov 20, 2004 08:21 PM
