Heater core question
Old Nov 20, 2004 | 07:30 PM
1976 ranger's Avatar
1976 ranger
Will a high output heater core work in a non high output heater assembly.
Thanks
David
Old Nov 20, 2004 | 08:21 PM
ivanribic's Avatar
ivanribic
I do not believe so. The regular heater assembly has the same size opening as the high output unit but there's a molded bracket to hold the heater core which will not allow the high output core to fit. I wish I would have taken pictures of mine when it was apart so you could compare. I'd be curious to see if one could cut out the bracket with a Dremel or similar and fit a high output core in.
But as it is now the HO core will not fit the regular assembly.
