Sponsored by: Kumho
Rear leaf spring questions
Old Jan 22, 2022 | 03:09 PM
jerryparks's Avatar
jerryparks
Hey folks
I have a 1997 F-250HD (Old Body Style) with a service/utility body (the kind with all the doors on it). The truck has 275k miles on it, and still rides on the factory suspension (as far as I know).
In the rear, I have a 3+1 spring set up, spring code on the door is "MF".
C9 Axle, Rear GAWR is 6084lbs. The empty weight on the rear axle is 3500lbs, fully loaded I'm anticipating it to be 4000lbs.
What I've found for the "F" spring code for 1997 is for either F350 trucks or F250LD trucks. The F350 springs are a 4+1 design rated for 2,700# spring capacity. The F250LD springs are 3+1 design rated for 1,400# spring capacity (this was on trucks with under-8500# GVWR, mine is over-8500 GVWR).
I'd like to upgrade the suspension so the rear end no longer sags. Am I safe to buy a 4+1 spring set rated at 2800# per spring, or should I upgrade to a 6+1 spring set rated at 3100# or 4200#.
Empty the trucks weight (per the CAT scale)
GVW - 6500
Front GAW - 3000
Rear GAW - 3500
And I expect to carry an additional 500+ pounds in the bed daily.
Thanks all.
Old Jan 23, 2022 | 07:43 AM
JWA's Avatar
JWA
Personally I'd contact a local "big truck" spring shop to get their input.
Is your rear axle full floating or semi-floating? That will make a difference I'm sure,
RKW
Jul 31, 2021 10:01 PM
Lightning23
Jan 24, 2021 08:26 AM
My1964ford
23
Mar 9, 2017 07:27 PM
GAHIGHRIDER
May 2, 2016 11:24 PM
Fomocosho1
Jul 17, 2006 06:21 AM
