Rear Spring Rate
Old Jul 16, 2006 | 04:20 PM
Fomocosho1's Avatar
Fomocosho1
Rear Spring Rate
Does anyone know what a good spring rate would be for a 50 F1 rear spring. Truck will be used for cruising and not hauling. I will be making my own spring hangers to get the spring under the frame so I figured I would get some cheaper universal springs.
Thanks
Old Jul 16, 2006 | 07:07 PM
49willard's Avatar
49willard
I do not know what the original spring rate was, however, I did some load test measurements on my original springs and I think that the original spring rate was approximately 240#/inch. After removing 3 leaves from the rear I measured approximately 170#/inch. I have not run my truck yet but I think that others on the forum have run the setup with 3 leaves removed from the original rear springs.
Old Jul 17, 2006 | 06:21 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Fomocosho1 to Ford Truck Enthusiasts!
See you on the boards. ….
