1986 4.9L spout plug
Old Jan 20, 2022 | 08:56 AM
raye321's Avatar
raye321
The plug on my van looks a bit different than the photo but in the same location. I timed the engine to 10 degrees TDC. Reconnected the plug then checked the timing. The timing mark was showing to the left of 10 degree mark. Is that what it should read with the wire plugged in?
Old Jan 20, 2022 | 11:11 AM
econo93's Avatar
econo93
What photo? You mean on the other thread?
You should continue on that thread instead of starting a new thread with each new question
Old Jan 20, 2022 | 05:06 PM
raye321's Avatar
raye321
Yes econo93. I first tried to post on that thread but it wouldn't let me. I don't know why.
The plug is not square but more like cigar shaped. I timed the engine and lined up the marks at 10 degrees BTDC. Reconnected the plug and checked timing. The mark moved to the left of the 10 degree mark. I'm wondering if it is supposed to that.
Old Jan 20, 2022 | 05:12 PM
raye321's Avatar
raye321
Update: I tried posting on the original thread and it worked this time. Must have been something wrong with internet connection.
Old Jan 21, 2022 | 04:43 AM
manicmechanic007's Avatar
manicmechanic007
The early spout plugs were round and had to be pulled apart
The movement to the left is normal indicating that the timing advanced some as soon as you reconnected the spout
That means it is working correctly
You'd be surprised to see just how much timing the processor gives it at times
Old Jan 21, 2022 | 09:28 AM
raye321's Avatar
raye321
Thanks for the info. Good to know it's working correctly. The engine is running smooth and quiet. I installed new timing gears replacing the fiber cam gear with aluminum gear and steel crank gear. I read that it would be noisier but I don't notice any change.
Old Jan 21, 2022 | 12:14 PM
manicmechanic007
Good on ya
Those gears will last forever
liljohn
Oct 21, 2011 01:11 PM
gt4660
Jul 28, 2010 02:49 PM
TLI
Feb 11, 2010 08:08 PM
n0mxj
1983 - 2012 Ranger & B-Series
Aug 2, 2005 12:43 AM
ronnnn
Sep 11, 2003 09:08 AM
