Spout Plug fro Timing
Old Feb 10, 2010 | 06:26 PM
TLI's Avatar
TLI
Where is the spout plug you are supposed to unplug to set the timing on a 1994 5.8???
Old Feb 10, 2010 | 06:37 PM
White 97 xlt's Avatar
White 97 xlt
It is below the drivers side hood hinge.. at least that is where it is on a 97 250HD OBS
Old Feb 10, 2010 | 09:00 PM
DasCheckers's Avatar
DasCheckers
Your Spout Plug will usually be located directly under your OBD I Test Port.
And your Spout Plug will look like this.
Old Feb 10, 2010 | 09:34 PM
truckrider814's Avatar
truckrider814
Ok not to hijack on the tread but what if you can't find that where it's suppose to be. i've looked there and by the distributor and all over and can't find anything that looks like that.
Kyle
Old Feb 10, 2010 | 09:39 PM
DasCheckers
Oh you have a 351...I have no clue. I'll step down and wait for a 352 guy to speak up.
Old Feb 11, 2010 | 01:26 AM
Sbrown's Avatar
Sbrown
On my 91 302 the spout plug is right by the distributor, although there is a connector by the drivers side door hinge that has the same connection/connector as the spout plug by the distributor....are there two spout plugs?
Old Feb 11, 2010 | 01:32 AM
DasCheckers
No, there should only be one.
Old Feb 11, 2010 | 10:54 AM
Conanski's Avatar
Conanski
The spout plug is in the TFI wiring harness which should be on the drivers inner fender on that truck...
Old Feb 11, 2010 | 08:04 PM
mstromni's Avatar
mstromni
So..what happens if you set the timing at 10 deg BTDC with a warmed up engine at normal idle speed, and the spout connected?
Because that's what I did after I put a new timing gear in (4 deg advanced). Truck has never run better. I guess I forgot about this SPOUT thing. Is my timing retarded more than it should be?
Old Feb 11, 2010 | 08:08 PM
TLI's Avatar
TLI
Thanks for the pics. I found the plug I think my hand was covering it up when I was looking for it. (ha, ha)
tempest411
24
Jun 5, 2025 11:11 PM
Sampson767
Nov 4, 2015 03:19 PM
BII Plow Truck
Jun 28, 2013 10:10 AM
Nally427
Aug 6, 2012 12:50 PM
don2007
Apr 27, 2008 06:05 PM
