transmission swap
Old Jan 17, 2022 | 12:36 PM
Retiredin2019's Avatar
Retiredin2019
4wd High
transmission swap
Looking for info on transmission swap on a 1992 f150 4x4 4.9 with the 5sp mazda tranny, would like to upgrade to a zf5. I know the new transmission will need to be from a small block truck, but will my current transfer case bolt up or will I need to change it as well? also understand that I will need the crossmember from the zf truck as well. TIA for any info or direction anyone can give. car-part list the following options as replacements not sure of the difference
MT, 5 speed, ZF manufactured, 4x4, ID E9TA-TA
MT, 5 speed, ZF manufactured, 4x4, ID E9TA-TB
MT, 5 speed, ZF manufactured, 4x4, ID F2TA-PA
Old Jan 18, 2022 | 08:51 AM
jas88's Avatar
jas88
Yes the transfer case will bolt up. My truck had a Mazda trans and I put in a ZF5 when I converted to the 460 and I used the same crossmember.
Old Jan 18, 2022 | 07:10 PM
Retiredin2019
4wd High
so its basically a direct swap as far as main components go? No adaptors or extra parts?
Old Jan 19, 2022 | 08:50 AM
jas88's Avatar
jas88
Not sure about length of driveshafts, tho.
Old Jan 19, 2022 | 12:02 PM
Hit Man X's Avatar
Hit Man X
Hydraulics, at least the slave. The 4.9 fly can accept an 11" clutch, so may as well pop one in while down.
I can measure a 2x4 small block M5OD and a 2x4 Diesel ZF if it will help. My guess the DS will need to be shortened some.
Old Jan 19, 2022 | 12:55 PM
Robfinger's Avatar
Robfinger
Actually iirc it's other way around, the Mazda transmission is very long while the ZF is a tall but fairly short beast.
Also yes on the hydraulics, master can be reused but the slave will need changing. The line will need some creative reshaping with a heat gun too as far as I remember.
Old Jan 19, 2022 | 01:03 PM
Hit Man X's Avatar
Hit Man X
When I rebuilt my ZF I remember it was portly, around 180lbs! Not enough time under my 4.9 to really recall the M5OD.
If the line is different, I would probably buy all new hydraulics.
While down, pop in new pedal box bushings. The difference is shocking.
Old Jan 20, 2022 | 04:38 AM
EPNCSU2006's Avatar
EPNCSU2006
The slave cylinder is the same between the Mazda and ZF, and I would imagine the line is the same too (the clutch is in the same place on both transmissions). Ford changed the hydraulics beginning on '93 models, but the master and slave are both different than the '92 - as long as master/slave are from the same model year you'll be fine.
I attached the latest part number chart from ZF before they removed it from their website. It shows all the various transmission part numbers you can look for used.
Old Jan 20, 2022 | 10:29 AM
Robfinger's Avatar
Robfinger
Oh that's right, completely forgot the small-block ZFs use the internal slave! Yeah the hydro line should fit just fine then, I was thinking of the big-block and diesel transmissions that have an external slave when I first mentioned the line possibly not fitting quite right.
flipboard7431
Jan 18, 2014 08:39 PM
Kenneth's68
May 24, 2010 03:14 PM
10strokin
Jun 22, 2009 02:29 AM
btacarlton
Nov 6, 2005 12:04 AM
tazaxx
Nov 13, 2003 08:37 AM
