7.3 Batter Cables?
i hear about others using welder cable. What do you suggest and does it matter if I get it local or online?
also, the terminal connections…lots of people using marine connections and military style connections…planning to make this truck a welding rig in the future. What do y’all suggest? What have y’all used?
on a budget so I’m not wanting to buy a $300 set of new cables from all these diesel sites
Link: https://www.ford-trucks.com/forums/1...l#post20222208
https://www.ford-trucks.com/forums/1...ry-cables.html
Other links found in that thread probably have even more answers, some for questions you dont even know to ask yet. Be prepared to go down a rabbit hole.
EDIT: The living FTE index (@Sous) beat me to it. He claims he saves links for stuff like this, secretly I think he's a bot and just pulls it out of that memory bank that he calls a brain.
Get welding cable (I think it is size 00 hat I used?). I started from scratch and dont regret it one bit. It is much more pliable to work with. Making your own, you can change the length a bit to get a better fit/routing if you feel it is necessary. You mention setting your rig up as a welding truck, so I assume you know a bit about how fastening the connectors to the wiring. A half a$$ connection pretty much negates the advantage you have with nice wire. The raw wire isnt cheap, but you should be able to rattle off something for less than the $300 you note.
I made all my own copper terminals with copper tubing pressed flat and drilled with a step bit and used a hydraulic crimper on the cable ends.
Then I used 1 inch heat shrink with the adhesive to seal up the cable ends.
My truck will start in about 5 seconds with only the driver side battery connected instead of 2-3 seconds with both batteries.
and do you have a link to it? The shop in my town sells by the foot but the biggest they said they have is 1/0 or 2/0
