Problem with System charge rate low
Old Jan 5, 2022 | 11:29 PM
upanddownau's Avatar
upanddownau
I get an intermittent message advising my charge rate is low and service now. The little red battery icon shows on the dash after the message flashes.2 Auto Electricians have tried to find the source of the problem and others in the forum suggest it is due to fitting 850cca lithium batteries - which I'm sure if that was the case the message would be on all the time. I ran a forscan and the OBD showed the following:
DTC's in PCM - P163C . 00 -2F
Generator B Field Terminal Circuit Low
Malfunction indicator amp is off for this DTC
Pto Status is off>
BECM B Battery Energy control module shows:
Batt_V_Inf, V
0.00
Batt_Discharge_ Inf
Vehicle is a MY2018 F250 Platinum Diesel
Checked the charge rate and 13.7v and both batteries fully charged - Auto Elect's said that's perfect. Lithium battery manufacturers said there isn't any problems with heat - the under bonnet temp in the F250 is bloody hot.
Anyone able to suggest what to look for in the way of malfunctions?
upanddownau
Jan 12, 2022 04:07 PM
upanddownau
Jan 6, 2022 04:15 PM
Tedster9
1983 - 2012 Ranger & B-Series
39
Jun 23, 2020 08:33 PM
JWA
Garage & Workshop
15
Jan 15, 2014 06:43 AM
allisdeere
Modular V8 (4.6L, 5.4L)
Feb 7, 2008 08:34 PM
