Tow Mode...do you use no matter the weight and/or distance??
I just took possession of my F350 6.7 diesel. I often tow a small boat (under 5000#'s) short distances (less than 10 miles). Should I always use tow mode whenever I hook up any trailer to my truck, no matter the weight and/or distance?
Thanks guys.
Thanks guys.
The following users liked this post:
The gist is, Tow/Haul is a preference not a requirement to tow. You will not damage your truck by not using it. I am in the camp that likes it going uphill, hates it going downhill and generally I do not use it at all rather I lock gears out or use manual mode if I need more control of the trans.
The following 3 users liked this post by RidgwaySD:
Definitely true 20yrs ago. My 01 f250 PSD would downshift all the time trying to go into O/D if you didn't turn it off. Would cause the trans temps to really climb. When o/d was turned off it shifted (and down shifted) less and ran much cooler.
The following 2 users liked this post by Split rims:
