Sponsored by: Real Truck
Alarm lockout
Old Jan 3, 2022 | 09:02 AM
electricsmith's Avatar
electricsmith
Alarm lockout
Good morning everybody. I am attempting to install a new dash in a 2009 f350 5.4. The dash lights on the old dash would not shut off so figuring it to be an ignition switch issue i found a nice lariat dash. once installed i attempted to start it with the lariat key and fob and it is in alarm and will not turn over. the key seems to be a door key bit not sure. Let me know any ideas. thank you.
Old Jan 3, 2022 | 12:15 PM
Just Strokin's Avatar
Just Strokin
I suspect the PATS is in the BCM and to use the Lariat Key, you would need to have PATS reprogrammed. Try changing the lock cylinders to your old key and then try starting the truck.
Old Jan 3, 2022 | 08:20 PM
electricsmith
Thanks you. i will give it a go
HDSlowride
6.7L Power Stroke Diesel
Sep 15, 2021 06:31 PM
J Love
Jul 9, 2020 02:44 PM
4444me
Nov 12, 2012 03:28 PM
ZRXKUMA
1978 - 1996 Big Bronco
May 3, 2006 08:45 AM
GWB
Electrical Systems/Wiring
Aug 29, 2003 06:42 PM
