I had the camper package on my '04 F250, mainly to get the rear auxiliary springs and the rear sway bar, this also bumped my front axle +1 spring rating to 4800#. I did not order my '21 F350 SRW with camper package as it came standard with rear auxiliary springs, standard with 4800# front axle, and no rear sway bar, I added rear sway bar when I brought it home (easy install). Personally, I think more spring weight rating on the front axle hurts a WD hitch, as it makes it harder to transfer weight to the front axle. For your F250 application, I would not get the camper package (this is for a slide in / in the bed camper, not a pull trailer), and add the sway bar yourself. Philip.
I believe the 7.3 comes with 1+ front springs compared to the 6.2. I think its only 150lbs heavier or something around that. I would stick with the stock springs unless you plan to add a large front bumper.
Your trailer will be fine with your f250 king ranch 7.3. Will come with a 2.5” 15,000/1,500 hitch and most will recommend a W/D hitch to help with keeping it all even.
Great Thanks! Good to know the additional information. I have a Blue Ox WD.
I was able to find out if the KR with that set up has a sway bar. I have read about the additional front end spring is really only recommended if you have a winch or 5th wheel. Not sure if that’s correct or not?
A weight distribution hitch (WDH) helps return SOME of the weight lost from the front axle caused by the trailer tongue weight applied to the receiver. The WDH shouldn't cause the front axle to be loaded heavier when the trailer is attached. If it does then the hitch is adjusted way too tight.
For towing, particularly in mountains, I'd order a 4:30 differential because a 3:55 with larger tires is more like a 3:33. As another said, consider if you might get a larger camper.
Just for argument sake, a 6.2 with 4:30 might tow as well as a 7.3 with a 3.33.
FWIW, my camper package helper springs engage at approximately 2 1/2 inches.
I am pretty sure I have seen empty weight specs here and the 6.2 is actually 60-70 lbs heavier than the 7.3. The 7.3 is certainly a more compact design than the 6.2 so this didn't surprise me.
Thanks for help solve the front spring mystery. So gas base is 4400, heavy service is 5200 and snow plow prep is 5600. I haven't seen anyone post their heavy service numbers before.
20" with AT tires have the same or more load rating than the 18" with the AT tires. 18" with the standard tires have lower load rating.
The ford towing guide has all that information.
Trucks with the 20” wheels and AT tires or 18” wheels and AT tires have the same GVWR and rear GAWR specs. Trucks with the 18” wheels and A/S tires have lower ratings because the tires are smaller.
The Spec Brochure is a good source for detailed info.
thanks again !
My understanding is the front spring upgrade is determined by drive train, not by engine. AFAIK, a 4x2 with the camper package (like our truck) gets the +2 front spring increase, and 4x4’s get +1.
I looked this up when I made my order and the 7.3 f250 is heavier from what I remember. But I could be wrong.
Ford’s specs indicate the 7.3 weighs ~30-40 lbs. more than the 6.2; see chart below.
I doubt many people order the heavy service front. Since I couldn't get the camper package with my KR, and since I was going to attach a Ranch Hand Legend to the front (like 330lbs), I had two options , but didn't feel it was worth the plow prep in Texas. It likely didn't need any help with the front, but I figured it couldn't hurt. My '20 F250 FX4 7.3 with Camper Package had 4600 front GAWR, IIRC.
