3 speed top loader question
Old Jan 18, 2022 | 11:15 AM
  #31
53NAA's Avatar
53NAA
Final update-
I got the shaft machined and the spacer washer installed. The mainshaft went together well and I ended up with .004 endplay which is great. I installed replacement roller bearings as well since a couple of the old ones were sketchy. The cluster gear with the new thrust washers went in quite well and ended up within spec on endplay ()
Thanks for everyone’s suggestions and comments to help me with my first dive into the top loader 3 speed.
Old Jan 20, 2022 | 01:35 PM
  #32
ALBUQ F-1's Avatar
ALBUQ F-1
Should give you many miles of service! Good job!
Old Jan 20, 2022 | 05:47 PM
  #33
wellcraft17's Avatar
wellcraft17
Great job, what gear lube are you planning on using?
Old Jan 20, 2022 | 08:42 PM
  #34
3twinridges's Avatar
3twinridges
Nice restoration.
JB
Old Jan 20, 2022 | 09:59 PM
  #35
tip49's Avatar
tip49
Nice work!
Way above my skill set, impressive job
Old Jan 21, 2022 | 06:34 AM
  #36
53NAA's Avatar
53NAA
I went with Sta-lube 85-90W GL3/GL4 gear oil for the transmission. I’m running 140W GL4 in the differential. Both are supposedly brass safe.
Old Jan 21, 2022 | 08:02 AM
  #37
wellcraft17
I’ve always used 140wt. Gl1 in my transmissions & rear ends since the 60s without any issues.
William Cabot Boyd
Large Truck
Aug 11, 2016 03:41 PM
Daddyo's garage
WTB - Parts & other
Nov 2, 2013 11:08 AM
matthew28337
Apr 4, 2006 01:49 AM
