dual diaphragm booster needed
Old Dec 27, 2021 | 10:48 AM
F-250 WARHORSE's Avatar
F-250 WARHORSE
I installed a new dual diaphragm booster from Rock auto about 5-6 years ago I believe and now it is leaking and stiff on pedal. I can hear it and brakes are not as good now. 1979 with cruise. Everyone seems to not have availability any longer. rebuilt it or do without or something. Does anyone know of a source in stock or a core I can send off and/or rebuild myself? I like the brakes fine so I really have no desire/need to convert to hydroboost since I am sure that will be mentioned. To my knowledge (Bill will be first to explain 20+ booster/mc/pedal combos for 1979 alone!! THanks Bill) a 1979 f350 2wd is a dual diaphragm booster. 1978 has linkage, 1979 has rod. Cruise control has little flat switch boss on rod. The cruise control may be the least important aspect here. Hopefully this is enough information for help.
Old Dec 27, 2021 | 02:06 PM
mark a.'s Avatar
mark a.
Did you try Cardone ? maybe they would rebuild the booster you have.
Old Dec 27, 2021 | 02:22 PM
F-250 WARHORSE
Yeah, I would like to not have my truck down for the winter though.
Old Dec 27, 2021 | 03:43 PM
buckin69bronco's Avatar
buckin69bronco
I was able to swap in a 2005 F150 booster into my ‘79 F350 4x4. The rod needed to be bent just a little but length was good. I also had to aug out the stock firewall bracket holes to fit the booster but the MC side matched the stock MC bolts. It also took a spacer to be put in the MC to fit for the booster to MC rod.
this change did take some work but the brakes are better than they were before and now I have a booster that’s actually replaceable if it dies.
Old Dec 27, 2021 | 06:20 PM
5851a's Avatar
5851a
Old Dec 27, 2021 | 06:29 PM
F-250 WARHORSE
thanks for the leads guys. I love this place. I need a core to have redone by these guys and be good to have one in service and one being rebuilt.
Old Dec 28, 2021 | 03:09 PM
jackietreehorn's Avatar
jackietreehorn
I’ve haven’t come across a part I couldn’t find yet….except the highboy fuel filler delete panel.
Found two DD boosters this year. Plug the various interchange part numbers into ebay.
Check craigslist, facebook etc.
I found another one in a junkyard this year.
Finally there are a few companies that offer rebuild and return services, even Cardone via rock auto.
Old Dec 28, 2021 | 08:40 PM
tbear853's Avatar
tbear853
A-1 Cardone 50-3311 - Google Search ..... what I used in my F-150 brake upgrade, with larger Thunderbird caliper pistons too. It was listed for F-350, but I feel sure it will work with a F-250.
Old Dec 28, 2021 | 11:38 PM
maddogjohnson's Avatar
maddogjohnson
Check your PM's for a note from me to help you out.
Old Dec 29, 2021 | 11:26 AM
F-250 WARHORSE
OK thanks I am not having much luck finding the 79 only. Might be able to swap rod and use the earlier one.
Old Dec 29, 2021 | 02:27 PM
jackietreehorn
The seller of those new DD boosters is also an FTE member btw. Glad to see a need being fulfilled.
Can anyone remind me why all the master cylinders come with those brass reducer things?
couldn’t they just thread the cylinder to the right size or is it a residual valve too?
Old Dec 29, 2021 | 10:15 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
What about these folks? https://www.battlebornbrakes.com/ford-trucks-73-79
https://www.battlebornbrakes.com/pro...ge-bore-master
Old Jan 16, 2022 | 08:48 AM
1STFOX's Avatar
1STFOX
I had my 1978 F350 dual diaphragm rebuilt at Cardone. I ordered the service through Rock Auto. I sent my booster out the day after Christmas
and received it back on Friday Jan 14.. So probably about a two week turnaround. Very pleased with this service. Cost was about $115. The do photograph
your booster and send you back the exact one you send in.
Old Jan 16, 2022 | 12:53 PM
maddogjohnson
Your PM box was full for a couple of days but I was finally able to get one to go through to you just now. The booster is on its way to you.
Old Jan 17, 2022 | 11:51 AM
jackietreehorn
before/after pics would be cool to see…
charter.pa
Nov 29, 2020 10:42 AM
winginit
15
Nov 2, 2015 08:17 PM
XTfx4
Mar 2, 2013 09:43 AM
Behemoth
13
Apr 9, 2011 10:49 PM
junkyardjeff
Jul 7, 2008 08:36 PM
