correct brake booster help?
Old Mar 2, 2013 | 08:35 AM
XTfx4's Avatar
XTfx4
hi all , been doing some research on which booster to get for my truck. Have a 1979 f350 4wd no cruise.. the numbers on my brake pedal read D8TA-2455-SA. which from what i have read is for 1979 f350 after DJ0001 w/cruise. and pedal rod from booster reads FT41 , from which i can tell is for a f250 w/cruise. being that my truck has no cruise which booster would fit the pedal i have...thanks .
Old Mar 2, 2013 | 09:43 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Your booster should also have an engineering number on it. See if you can find it. If you do, post it and I'll cross it over to the part number you need.
winginit
15
Nov 2, 2015 08:17 PM
deere tech
Jan 3, 2012 09:51 PM
tx78
Feb 4, 2008 12:21 AM
roscoe
Mar 22, 2006 11:00 AM
nate5812
21
Mar 6, 2005 04:34 PM
