Battery on trailer
Old Jun 14, 2023 | 08:04 PM
Flyct's Avatar
Flyct
FTE Community Team
Originally Posted by robert sloane
bingo
i use a set of diodes to prevent a HOT line on the 7 pin pig tail once its unplugged from the truck.
if trailer is plugged into truck and truck is OFF the power is removed from the 12v pin in the connection and will not back feed to trucks system, at least thats how its showed to be wired in the electrical book.
Using a typical silicone diode will drop voltage by 0.7 volts in forward bias. So if the truck supplies 14.0 volts at the truck side pin the battery max would receive would be 13.3 volts.
Old Jun 14, 2023 | 09:25 PM
1olddogtwo's Avatar
1olddogtwo
My gooseneck trailers have a large group 65 size battery to run lights, hydraulic jacks. They have only ever been charged by the truck.
Can you install a larger battery to aid in buffing the draw/recharge time?
My fuel trailers has two deep cycle batteries, they are charged also from the truck. Solar when not hooked up.
Old Jun 15, 2023 | 11:28 AM
DPelletier's Avatar
DPelletier
It all depends on drive time and how much power is being consumed daily but generally, you'll get VERY little charge from a truck unless you add a DC to DC charger. https://askthervengineer.com/youre-n...r-tow-vehicle/
Also, I'd echo JohnD333's comment that the 12V output leads on a Honda Generator are very poor for charging batteries; you'll do MUCH better plugging an actual battery charger into the genny.......may be all you need.
Dave
Old Jun 15, 2023 | 11:53 AM
John in OkieLand's Avatar
John in OkieLand
Dave
What the gentleman explains later on in that link,
is that lead acid batteries, ( and most others )
must be pushed to 14.5 volts for an extended amount of time, for the battery to actually receive a "Full Charge" and show 12.7 volts at idle for several hours after the key is OFF.
12.6 volts is marginally at Full Charge.
12.5 is on the way down.
12.1 is almost dead for practicable purposes.
if the engine is in good condition, it might start, but that battery will need many hours at 14.5 volts to recover to Full Charge.
My Alternator regulates at ~15 volts
intofire56A
Aug 2, 2021 05:53 PM
MisterCMK
2021+ F150
May 19, 2021 10:21 AM
Rudefish
2015 - 2020 F150
May 11, 2021 11:34 PM
Superblue400
2015 + Expedition & Navigator
May 3, 2021 01:52 PM
old farm truck
General Automotive Discussion
Dec 15, 2014 01:29 AM
