Trailer Battery not charging
Old Sep 4, 2017 | 06:09 PM
Rudefish's Avatar
Rudefish
Has anyone got the warning that says Trailer Battery Not Charging See Manual?
My buddy has a 2016 F 150 and has been getting that message pretty regularly and he is towing his boat without a battery on the trailer.
Old Sep 4, 2017 | 07:30 PM
seventyseven250's Avatar
seventyseven250
I wouldn't worry unless he also gets that message when do tows a trailer with a battery.
Old Sep 4, 2017 | 07:43 PM
Rudefish's Avatar
Rudefish
It's a common thing that happens and it's pretty annoying. Just tying to help him figure out how fix it.
Old Sep 4, 2017 | 07:52 PM
GlueGuy's Avatar
GlueGuy
Maybe you can add a battery to the boat trailer? <<ducking>>
Old Sep 4, 2017 | 11:22 PM
seventyseven250
I like how you think
Old Sep 5, 2017 | 12:42 PM
cub129's Avatar
cub129
When he set up the trailer did he select electric brakes? Try changing to no brakes (if an option).
Old Sep 5, 2017 | 02:41 PM
jd50i's Avatar
jd50i
Trip to the dealer
SSM 45236 - 2015 F-150 - Trailer Disconnected And/Or Trailer Battery Not Charging Displayed In The Message Center
Some 2015 F-150 vehicles may exhibit a trailer connected then trailer disconnected and/or a trailer battery not charging message displayed in the message center when no trailer is being used. To correct the concern, reprogram the Trailer Module (TRM) to the latest calibration using IDS version 96.01 or higher. Make sure you are connected to the internet when entering module programming to obtain the latest updates. Calibration files may also be obtained at www.motorcraftservice.com. Use causal component 19H332 and applicable 12651D labor operations from Section 10 of the Service Labor Times Standards manual for reprogram only.
APPLICABLE VEHICLES
2015 TRUCK: FC P552 F150
2015 TRUCK: 00029 F-SERIES LD
Old Sep 5, 2017 | 04:37 PM
storage_man's Avatar
storage_man
Originally Posted by jd50i
Trip to the dealer
APPLICABLE VEHICLES
BUT BUT but - the OP states it's happening on a 2016 ?
Old Sep 5, 2017 | 04:53 PM
jd50i's Avatar
jd50i
Jan 7 2016 2478 - 2015-2016 F-150 - Trailer Disconnected And/Or Trailer Battery Not Charging Displayed In The Message Center
Some 2015-2016 F-150 vehicles may exhibit a trailer connected then trailer disconnected and/or a trailer battery not charging message displayed in the message center when no trailer is being used. To correct the concern, reprogram the Trailer Module (TRM) to the latest calibration using IDS version 98.04 or higher. Make sure you are connected to the internet when entering module programming to obtain the latest updates.
https://ford.oemdtc.com/1195/trailer...016-ford-f-150
Old Sep 5, 2017 | 05:00 PM
jimmy-six's Avatar
jimmy-six
Might go away if you put the fuse in that was in the glove box when new if it has a trailer tow package. Other wise I can't see why it was on. I towed an enclosed trailer with a battery and never got any message except it was connected and all the lights were working properly. When I put the fuse in no new message was added but the battery charged.
Old Sep 5, 2017 | 05:15 PM
jd50i's Avatar
jd50i
he has no battery to charge
Old Sep 5, 2017 | 05:58 PM
jimmy-six's Avatar
jimmy-six
I understand that, but computer that checks the trailer comnnections may not. If he has a breakaway for electric brakes he does and that's what it maybe looking for.. If surge brakes it still could be looking for a battery. I'd put in the fuse if he hasn't.
Old May 11, 2021 | 11:14 AM
Jim Brunner's Avatar
Jim Brunner
Where would he put the fuse?
Old May 11, 2021 | 04:37 PM
scott91370's Avatar
scott91370
He wouldn't because it would already be installed.
How do all these new people keep digging up 3+ year old threads?
Old May 11, 2021 | 11:34 PM
JKBrad's Avatar
JKBrad
They get caught in that annoying infinite scroll.
old farm truck
General Automotive Discussion
Dec 15, 2014 01:29 AM
jasonodsky
Jun 15, 2013 05:39 AM
Beast12
All Things Towing
16
Jul 14, 2008 08:40 PM
white_2kgt
Electrical Systems/Wiring
Mar 22, 2006 12:05 PM
tsheriff
Jul 12, 2004 09:02 PM
