Does The Trailer 7 Pin Connector Charge Trailer Battery and provide Power Trailer?
Because, with the trailer battery disconnect, truck running, trailer wire connected to truck, trailer power jack has NO power and either does trailer (battery switch is "on").
Why I ask, my friends truck, F250 2016, powered the jack. Mine 2019. 2018 F150 will not do it either.
How do I know the truck is charging trailer system?
I know the connector has a Orange battery (+) wire, see attached picture (manual). Does this charge the trailer battery?
There is no fuse in the "trailer tow battery charge relay, Is this only for aftermarket systems?
THANK YOU, Rick
THANK YOU, Rick
THANK YOU, Rick
THANK YOU, Rick
Not an expert but have read several discussions on this here.
This may help: https://www.ford-trucks.com/forums/1...a-trailer.html
It looks as if, after reading links given, that there a module controller that only activates when the truck brakes or trailer brakes are applied (tested with conductivity tester), next want test for voltage, but I understand it is only enough for low voltage charging, not for power jack, but a couple guys there can operate the jack, like my buddy (2016), one gentleman stated he found the fuse in wrong spot, so I'll check that, I do have during my test --trailer brake activation, and all lights, just can't operate trailer power jack with trailer battery disconnected ( simulation of a dead battery),
I have not hooked up anything requiring AUX power .... But I have read quite a few threads on this for knowledge incase I need. So I have no current issue.
But, in all the reading I find it completely confusing. For some it seems everything works fine right off the lot. For others, they read and learn about hooking up trailer wiring and appling the brake to activate the system (with the door closed apparently). Others have had problems with a wiring harness under truck not being seated properly, a fuse missing or in the wrong location, and ...... In one thread I read where a guy was missing a complete section of trailer wiring harness under the truck.
From everything I've read ...... If I needed to use aux power....... I think I would hook it up and see if it works. If it does great. If not I would try activating by applying the brakes with the door shut.
If it does not activate/work or if I needed more power (after checking connectors, fuses, etc) I would either:
1). Run a wire (6 or 8 gauge) directly from the battery to the AUX power pin (cutting the factory wire and connecting my wire to the pin). ..... Of course with an in-line 30 or 40 amp circuit breaker. I like circuit breakers cause u can reset without keeping up with fuses.
Or
2). Instead of running from battery I could hook up to upfitter 5 or 6 and run to AUX power pin.
It sounds like for most that need more power for a power jack or other source, that either 1) or 2) are required.
What I have not seen, is a factory amp/amperage spec for the AUX power pin so that someone could make an easy determination. It seems that most have done a fair amount of trial and error to determine if a new power source for the AUX pin is needed.
I simply bypassed my trailer module by splicing in a 6ga wire with an in-line switch from the red wire which is on the bottom connector of the module to the orange wire on top. I did this so it works as factory with the switch open then when closed I can supply power to my removable slip tank pump that I have wired to a 7 way trailer plug in my bed. Works great and never had an issue, of course my aux lift pump is only a small 8gpm unit that has a FLA of 12 amps. There’s simply way to many times I need to power something with that 12v wire, this for sure wasn’t one of fords better moves. As smart as the computer is it will not charge my house batteries on my trailer or even keep them topped off. When I tow with a buddies 17 L5P or my old 07 Cummins the batteries stay charged 100%. So far only one of the “true” things I dislike about this truck.
Chase,
Chase,
