Break in
Old Dec 24, 2021 | 08:46 PM
1966F100SC's Avatar
1966F100SC
Break in
Getting ready to fire the rebuilt 352 tomorrow. Ken from Oregon Cams has gotten me the process for the cam side of break in. Now for the rest of the engine I have ready many different things on how to drive to get the rings seated, but opinions vary. What’s the general consensus for this time on how to drive
Old Dec 24, 2021 | 08:57 PM
Boss9F100's Avatar
Boss9F100
Key is getting it to fire instantly with timing spot on. Fuel in carb ready to go. If you have to crank it a lot or timing is off and you have to mess with it much it can kill the hydraulic lifters/cam in a hurry.
I have my own way of breaking in the rings and have had 100% success but most don't like to hear it.
Equal as important is what was done put on rings at time of engine assy. was proper machine work done etc all has more to do with it than how it's driven to get cylinders to wear for proper ring seal.
Some think it's rings wear but its actually the cylinders wear to rings.
Old Dec 24, 2021 | 10:25 PM
1966F100SC's Avatar
1966F100SC
What’s your method of doing it? And I made sure to clock all rings in the correct orientation, what a pain but hopefully with it.
Old Dec 25, 2021 | 08:45 AM
Crop Duster's Avatar
Crop Duster
Everything Boss9 said. Assuming your cam break in goes well. Just drive it like you stole it.
I always break in the cam on a run stand, 75% of the time the rings have seated just running in the cam.
One thing to be aware of running in that cam. An engine running at 2000-2500 with no load on it needs a lot of advance. Use your dial back timing light and make sure you are getting at least 40 degrees of advance, or you will get very high EGT's.
Old Dec 25, 2021 | 11:08 AM
1966F100SC's Avatar
1966F100SC
Rodger that!
realized this morning that I installed the rear main seal incorrect.
I put the lip opening facing towards towards the trans. Please correct if I am wrong!
so since I have to pull number 5 cap, any tips on pulling the cap off? It’s been difficult I don’t know if I do it right. I know how to put the seal in, just pulling the cap is difficult
Old Dec 25, 2021 | 11:17 AM
lizardman1's Avatar
lizardman1
I always offset the seal halves about a 1/4 inch so the seam is not inline with the bearing cap. Use a little bit of ultra black at the cap corners to insure no leaks.
Old Dec 25, 2021 | 12:36 PM
Crop Duster
FE's can be PITA. Just use a non-marring hammer and tap it back and front until you can pull it out. If you used a lot of sealer, it could take a while.
Old Dec 25, 2021 | 02:17 PM
1966F100SC's Avatar
1966F100SC
I only used a dab of sealer on the ends of the seal, not much. Hopefully all goes smooth
Old Dec 25, 2021 | 07:15 PM
1966F100SC's Avatar
1966F100SC
Got the seal fixed without issue
Old Dec 28, 2021 | 06:27 PM
BarnieTrk's Avatar
BarnieTrk
1966F100SC,
So do you have the bottom buttoned up and the oil pan and exhaust installed now?
- When I am ready to light the fire on a fresh build, I make sure to have a CO2 fire extinguisher at the ready......ya just never know what will happen.
- I also will put the battery on a charger for an hour or so, to ensure it is 100% up.
- How long has it been assembled - you may want to spin the oil pump drive with a drill to get oil throughout the block and valvetrain, ensuring lube prior to ¨lighting the fire¨....
Good Luck and report back!
BarnieTrk
Old Dec 28, 2021 | 09:10 PM
1966F100SC's Avatar
1966F100SC
Cam break in went well, now time for tuning.
I can’t get it to idle below 2000k rpm and the timing is around 25degrees at that rpm so something has to be wrong. All vacuum ports on the carb are plugged including the one on the dizzy ( disconnected of course)
it’s a 1406 carb, and I’m new to this. I have set the idle mixture screws 1.5 turns out from seated. I cannot get it right and I have chased the issues all day!! Please help!
and during building I verified that the tdc mark on the balancer was correct.
Old Dec 28, 2021 | 09:29 PM
lizardman1's Avatar
lizardman1
Is the carb a manual choke or electric? Also check the idle set screw and see if it is making contact with the screw stop. If not then possibly the choke fast idle is stuck. Also with the engine off and key off, look down in the carb and check to see if the throttle plate is cracked open. If it is, then you need to figure out if the choke is causing the problem or if the idle is set too high via the idle screw. Post some pics of the carb if you can. good luck
Old Dec 28, 2021 | 10:03 PM
1966F100SC's Avatar
1966F100SC
Electric choke.
where are the fast idle linkages at? Fir now I have a screw driver holding the choke open since it’s warm out. But it’s not long enough that it touches the butterflies
Old Dec 28, 2021 | 10:55 PM
1966F100SC's Avatar
1966F100SC
Could it be that the cam is off a tooth?
Old Dec 29, 2021 | 12:02 AM
Christmas's Avatar
Christmas
I would suspect the carb not being set up correctly.
