battery light +
Old Dec 10, 2021 | 12:17 AM
Samsonsford's Avatar
Samsonsford
battery light +
Battery light stays on. Charging gauge seams accurate. Checked wire to alternator, clean now and well connected. What else am I missing?
Also parking brake handle broke off in my hand.Where would I get another one? Temporarily rigged a wire with a washer handle. Thanks for any info. John
97 diesel DRw flatbed 4X4
Old Dec 10, 2021 | 03:15 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Don't trust the gauge in the cluster.
Did you use a multimeter or voltmeter to check for voltage at both battery terminals?
Did you use a multimeter or voltmeter to check for voltage at the B+ terminal on the alternator?
Is the connector on the alternator secure and are the contacts clean?
How do the wires coming from the alternator connector going into the harness look and test?
Did you recently perform any maintenance in any of the battery or charging circuits?
Old Dec 10, 2021 | 05:22 PM
Edgethis's Avatar
Edgethis
It's possible your alternator is going out. My kept the light on like that and I found out it was overcharging the system.
Before you buy anything, check the wiring out and test things with a multimeter like Sous mentioned.
Old Dec 11, 2021 | 11:27 AM
Hit Man X's Avatar
Hit Man X
Thumbs up
The white stator plug could be failing causing your issue. Happened to me and many other 3G folks.
LMC for the ebrake
Old Dec 11, 2021 | 05:18 PM
Samsonsford
Thanks HMX. Will chk. now . What is 3G btw ? John
Old Dec 11, 2021 | 05:29 PM
Edgethis's Avatar
Edgethis
3G is the style of alternator
Old Dec 11, 2021 | 07:57 PM
Samsonsford
Thanks. Busted P brake handle, any thoughts? I have exhausted my google capacity for that specific part. No need for the cable just the handle. Thanks
Old Dec 11, 2021 | 08:50 PM
Edgethis's Avatar
Edgethis
Not sure if the handle is available seperate from the cable. I didn't find it when doing a quick search. I did find a universal parking brake handle that you could probably make work with some super glue.
https://shop.advanceautoparts.com/p/...E&gclsrc=aw.ds
Old Dec 12, 2021 | 09:02 AM
Sous's Avatar
Sous
FTE Emeritus
Additional information on the 3G, 4G and 6G alternator cases is below for use of future readers that find this thread.
Link: https://alternatorparts.com/ford-typ...ternators.html
Old Dec 12, 2021 | 11:07 AM
Hit Man X's Avatar
Hit Man X
Thumbs up
LMR LMC Maybe Rockauto under interior? Or post up some guys have parts trucks here.
Old Dec 12, 2021 | 08:38 PM
Samsonsford
Thanks I saw that but I need the rod as well. I will just make it up I guess.
dhag911
Aug 27, 2021 07:30 AM
Jly154
Aug 22, 2015 08:36 AM
Tex1986
1997 - 2003 F150
Feb 16, 2011 04:08 PM
jjarboe01
Mar 8, 2010 11:35 PM
swamprat
Electrical Systems/Wiring
Jan 15, 2006 02:11 PM
