HELP !
Old Dec 8, 2021 | 10:17 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question HELP !
Im installing the fuel canister in my truck and I CANT install the low hose from the canister to the fuel pump, are there any tips, tricks. ?
I know I should change to E-fuel, but in this moment I cant afford the price (at least 12,000.00 MX, plus importation to my country)
Thanks in advance.
Best regards.
Old Dec 8, 2021 | 11:23 AM
Dmco's Avatar
Dmco
Are you talking about the return hose (part 8 in this diagram) between the fuel bowl and pump?
If you haven’t seen it yet, check out the Fuel Pump Replacement guide written by Sam Miller.
Old Dec 8, 2021 | 12:33 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Yes thats the hose. I have read that write up several times and I dont see how that hose can be atached to the fuel pump. thats my problem. I have tried to push the fuel bowl and dice nada. It seems that need something to catch the hose and then push it to the FP, but I havent already.
Thanks a lot AMIGO. T
The write up, only put this:
Adjust all the hoses and be sure the clamps are on and positioned for easy access. (Once again, the lower hose will have to be clamped securely to the filter canister at this point since you won’t be able to reach it once the assembly is bolted down.) Lower the filter assembly back onto its pedestal, connecting the lower hose to the fuel pump as you go. Check that the wiring looms and connectors on both sides are positioned correctly. Adjust all three short hoses correctly and tighten the clamps. Remember to “aim” the clamps for easy access later, just in case there is a leak and you need to get to them with a screwdriver or ¼ inch socket. Don’t forget to reconnect the drain hose also. And CLOSE THE YELLOW WATER DRAIN LEVER.
Old Dec 9, 2021 | 01:00 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Someone else?
Old Dec 9, 2021 | 02:03 PM
BuddyBarnes's Avatar
BuddyBarnes
Sure you got 3/8 in hose? If so try some wd40 on the connection. When I changed mine when stock I never had this problem . I just wiggled and pushed.
Old Dec 10, 2021 | 12:51 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
BuddyBarnes, YES it is 3/8" hose (pic). I only could achieved to push to the point that you can see in the pic. I used vaseline.
Thank you for your input. best regards.
File Type: docx
Old Dec 15, 2021 | 05:13 AM
RubberDuck's Avatar
RubberDuck
Jose I would install the hose on the fuel bowl side along with the feed that's above it. Little diesel in the hoses and kinda "cam"it in there with lots of up and down wiggling with pressure against it. That's how I've always done it. Dunno if that helps.
Cody
Old Dec 15, 2021 | 08:16 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
CODY??? Glad to know about you AMIGO. I could install the low hose with a lot of work, but its done. Thanks a lot for your input.
Best regards and the best for you and your family in this holidays and a Happy and best New Year 2022. UN ABRAZO.
jasindude1
Apr 16, 2016 12:47 AM
78f3504x4
Jan 15, 2010 04:41 PM
Maximus172
Oct 6, 2007 12:38 AM
blaksmoker
Jul 9, 2007 07:57 PM
