Will this transmission cooler help
Old Dec 11, 2021 | 02:43 PM
Kaleb924's Avatar
Kaleb924
Im ordered this trans cooler and it just came in and Looks a little small, will this help my trans temps or do I need to get a bigger one?
Old Dec 11, 2021 | 02:51 PM
Edgethis's Avatar
Edgethis
Do you currently have issues with your transmission temps?
Old Dec 11, 2021 | 02:57 PM
Kaleb924's Avatar
Kaleb924
the truck is stock except for air filter and hydra tuner, temps will get up to 182 on my hour long commute to work if it’s around 70 degrees outside and I was told you shouldn’t be running that hot without towing
Old Dec 11, 2021 | 02:58 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Have you looked at the stock one? Hard to do worse than that. Until you start hitting 220-230 or so I wouldn't worry.
Old Dec 11, 2021 | 03:06 PM
Kaleb924's Avatar
Kaleb924
I didn’t think the obs trucks came with a trans cooler. I was told on an obs Facebook group that anything over 190 will start to cause damage to the transmission seals.
Old Dec 11, 2021 | 03:10 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Ah yes, Flakebook. 190's good enough to keep condensation down but unless you're sustaining 220 (which you might towing), then you're fine in the mid 180's.
The 95-97 pickups have a cooler barely adequate for a power steering cooler.
Old Dec 11, 2021 | 03:27 PM
Kaleb924's Avatar
Kaleb924
thanks for that information! Will send this one back and just order a 6.0 cooler in the near future.
Old Dec 11, 2021 | 11:29 PM
97-psd's Avatar
97-psd
That is a good idea. The 6.0 cooler works well
Old Dec 12, 2021 | 10:15 PM
fordman67's Avatar
fordman67
I had a cooler much like that and it was inadequate.
many run the 6l but I have the trucool 40k gvw cooler on 3 trucks and it's great. It also is easier to accommodate space wise if you have an intercooler.
Old Dec 13, 2021 | 07:35 AM
z31freakify's Avatar
z31freakify
Also the smaller 99-07 gasser job coolers and 7.3 are adequate, I run one in my OBS, had a 6.0 on there but "someone" hit it while installing a freshly build engine into my OBS.
Old Dec 15, 2021 | 11:38 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
I also have that trucool and works fine. Compact but enough, and I also have an intercooler, so no problem with space.
Old Dec 15, 2021 | 11:44 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
Look here: https://www.ford-trucks.com/forums/1...ns-cooler.html
95copperhead
17
Feb 18, 2019 09:48 PM
CPaulsen
May 15, 2012 07:21 PM
grizzly11
Jan 24, 2011 10:29 PM
hosoria
Aug 12, 2010 06:04 PM
Bubba828
Jul 15, 2009 03:07 PM
