Sealed unit trans?
Old Dec 6, 2021 | 06:03 AM
sibernut's Avatar
sibernut
Sealed unit trans?
I have a 2014 150, seems to be developing a hesitation going between D and R, or back. No visible drips on truck, but pink like trans fluid on driveway. I'm told this is a sealed trans, can't add fluid or service it. REALLY??!!
Old Dec 6, 2021 | 06:35 AM
RLXXI's Avatar
RLXXI
You can do both but it's a pita.
Old Dec 6, 2021 | 10:52 AM
sibernut's Avatar
sibernut
TKS!
so no way to check level? Thats what it feels like.
Old Dec 6, 2021 | 11:03 AM
catequipment's Avatar
catequipment
You can check the level and add fluid but as RLXXI stated it is less than ideal. The dipstick (if you want to call it that) is only accessible underneath the truck on top of the fluid pan flange. I’m sure there is a video on the internet that would point you in the right direction. You would also need an oil jug with some type of pump. I’m cheap so I used a new chemical sprayer that I bought for under $20. It had a brass nozzle that I cut and bent into a hook shape. It worked fine for me but there are better options available. Mine wasn’t leaking though. I just changed the filter and fluid.
Old Dec 6, 2021 | 01:32 PM
sibernut's Avatar
sibernut
Saw the utube. $238 for a friggin dipstick??
Tks, ill crawl under &see if it's low on fluid SEVERAL timed before i pay that.
Old Dec 6, 2021 | 05:34 PM
catequipment
Yeah definitely more than I want to spend. Checking it with the Ford provided dipstick isn’t a big deal just watch your hands. The exhaust is right there.
Old Dec 6, 2021 | 10:03 PM
RLXXI's Avatar
RLXXI
"Less than ideal" lol You win understatement of the year.
Op wear heat resistant gloves and get a hot sleeve for your arm as you still have to check it with engine running. If you need to add some you'll need a fluid pump to push it up into the dipstick hole.
You may or may not have a scan tool capable of reading TFT sensor data so just do it the old fashioned way and warm the truck up good after you check it cold.
Old Dec 7, 2021 | 06:16 AM
sibernut's Avatar
sibernut
TKS!! Got a Ford Fast Lane dealer, he says they'll check it next time in for free. Acts like it's low, pink oil on driveway. Looked for drips under trans area, none. Then it occurred to me there's trans fluid all the way to cooler, Ill check for drips there
Old Dec 7, 2021 | 12:11 PM
gDMJoe's Avatar
gDMJoe
Lightbulb
sibernut...
While it may not apply or be pertinent...
For your listening pleasure and reading enjoyment *.attachment.
Backwoods351
35
Aug 30, 2014 05:13 PM
BiggDogg77
Jan 30, 2013 07:01 AM
WorkVan58
Aug 4, 2008 07:28 AM
midnight1967
Jul 14, 2007 10:05 PM
cjbronco
1978 - 1996 Big Bronco
Aug 1, 2005 09:52 PM
