Wheel spacers
Old Jul 2, 2022 | 11:31 AM
4Kids's Avatar
4Kids
The Struggle Bus¯\_(ツ)_/¯
Were there any decent quality AFTERMARKET 18" wheels for the Excursion or Super Dutys of years gone by that did not need the 2" spacers?
Old Jul 2, 2022 | 01:33 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
AR172s are available in 16 and 17 inch, but not 18, they look very close to the factory wheels, but give you more width, and proper offset.
Old Jul 2, 2022 | 04:51 PM
4Kids's Avatar
4Kids
Tire Rack appears to have a couple 18" wheel options that would work to retain the 4.5" backspacing that we currently have with the OEM 7" wide +1" offset wheels:
KM522 ENDURO (9" wide, 0" offset)
XD811 ROCKSTAR II (9" wide, 0" offset)
Custom Offsets also has some options, including some 20" wheels. A lot of those are 10" wide wheels. I've heard they are good quality. I know nothing about the Tire Rack brands.
Does a 9" or a 10" wide wheel present a problem using it with the Excursion?
Old Jul 2, 2022 | 06:01 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
So I am running the 16x10s on mine and they fit perfect, no rubbing, and no cutting needed, the -25 offset ones push 2 inches of the width outward so its only actually slightly more inset then the factory wheels are.
Think about it this way, -25mm offset is 1 inch. You take the wheel, add 1.5 inches to each side to make it 3 inches overall wider, but then you push it outwards 1 inch, so its only half an inch more inset then the stock wheels.
The wider wheels made a major improvement to cornering and handling in general, the truck is a ton more stable in tight curves and sharp turns.
Old Jul 3, 2022 | 01:28 PM
GOT-DRT's Avatar
GOT-DRT
I have a set of the $800 2” steel spacers for sale is anyone is interested
brucephilly
Nov 19, 2010 01:41 PM
NV250
Jul 19, 2009 07:06 AM
threefiftyone
Oct 4, 2005 01:12 AM
BOOTROS
Feb 25, 2005 01:29 PM
snoVVman
Nov 30, 2004 10:24 AM
