Sponsored by: Real Truck
DO I NEED WHEEL SPACERS?
Old Nov 18, 2010 | 07:48 AM
brucephilly's Avatar
brucephilly
do i need wheel spacers? i want to put factory 20" wheels off an 08 onto my 02 4x4
Old Nov 18, 2010 | 08:33 AM
brd7666's Avatar
brd7666
I believe if you want to put wheels form an 05 and up onto a 99 - 04, then you will need wheel spacers.
Old Nov 18, 2010 | 10:30 AM
cartmanea's Avatar
cartmanea
Yes, the offset is about 1.5" different so most run 2" wheel spacers. When you take into account the cost of spacers and that they are a weak point though, I would just get new wheels with the correct offset.
Old Nov 18, 2010 | 07:49 PM
cdrmotorsports's Avatar
cdrmotorsports
I would agree with cartmanea, I've heard some horror stories of people having wheel spacers and them failing.
Old Nov 18, 2010 | 11:11 PM
big yeller's Avatar
big yeller
I had a 2004 f250 and I put 2006 20" OEM ford wheels on. Had no problem with them the entire time I had the truck. one point, the spacers I used had a raised centering ring to eleminate any wheel movement . Even without this type of spacer, because the spaccers have there own studs, they still won't move. I feel you will be fine. I'm with you, I really like the
20" 05 wheels. Very heavy duty
Old Nov 19, 2010 | 01:41 PM
psdmikee's Avatar
psdmikee
"Hub centric" is the term you need to look for in spacers and is what Big Yeller is referring to with the raised ring. Stay away from "Lug centric" spacers they can be vary dangerous because they allow the wheel to move slightly wearing down the rim and allowing the lug nuts to become loose then fall off. Get some good quality steel spacers with the studs attached, and stay away from aluminium. You do not want to cheap out in this area.
The 20's do look sweet.
bearsfan394
1997 - 2003 F150
Nov 21, 2016 09:12 AM
ginomachino
6.4L Power Stroke Diesel
Sep 2, 2016 08:07 AM
b1gbl0ck
Feb 15, 2016 08:08 PM
1992FordF150Custom
Sep 27, 2011 10:29 PM
Builttough 89
Dec 8, 2006 11:24 PM
