2003 f150. I was installing SVT HD lights and I snapped the driver side adjustment bracket. Can I use the one from the OEM headlight?
also, the driver turn signal isn’t sitting flush against the headlight and trim, it’s got a weird gap that is there even with the OEM turn signal. Anyone run into this? It’s not present on the passenger side, and it’s like it’s not sitting snugly in the bracket, as it protudes on the bottom against the white trim.
Sometimes after market parts dont fit quite right. ( chineese)... You might have to trim a bracket, or add a washer between the braket and mount to move things IN or OUT a little for better alignment..
