Help programming Brake controller
Old Dec 2, 2021 | 10:07 PM
Boaterguy's Avatar
Boaterguy
2018 F150 3.5 Ecoboost CC 4X4
Hey all,
Working on a friends truck, trying to program the factory trailer brake controller that we just added. After install, we plugged in the wiring harness and used forscan to enable trailer brake control module, and trailer brake gain module, as per instructions. When the truck is turned on,, display says "trailer brake control fault". Forscan indicates a DTC U0137. We have checked all the connections, fuses and wiring and cannot find a short.
Can someone point us in the right direction?
Old Dec 3, 2021 | 07:08 AM
SpencerPJ's Avatar
SpencerPJ
Is it a true Ford brake controller? Many posts about knock offs not working.
Old Dec 3, 2021 | 07:22 AM
99powerstrokedF250's Avatar
99powerstrokedF250
The above is true. Ford vehicles, for a long time now, have not played well with knockoff parts and components, particularly electrical components.
There is also the possibility that you got the wrong brake controller if you bought a Ford one, there was a change made right around the year of your truck, so if you happened to get the wrong one you could have a whole host of issues.
Old Dec 3, 2021 | 09:34 AM
JKBrad's Avatar
JKBrad
Also, is it a brake controller for 2018 and up or one for a 2105-2017?
Old Dec 3, 2021 | 02:52 PM
Boaterguy's Avatar
Boaterguy
I think he got it off of Amazon, so good possibility it's fake.
Boaterguy's Avatar
Boaterguy
Yes, it's supposed to be the correct year part, so we may pull it out, and reorder thru the local dealer.
Old Dec 5, 2021 | 05:11 PM
jake415's Avatar
jake415
Let us know how this issue plays out. Just curious, where did you get the part in question from? There are a bunch of counterfeit Motorcraft parts on the internet and Amazon. If the price was too good to be true, it probably was. There is a great video on Youtube about learning to spot counterfeit Motorcraft parts.
Old Dec 5, 2021 | 05:34 PM
Boaterguy's Avatar
Boaterguy
He ordered from Amazon. Price was about $60. Going to return it and order one online from Lakeland Ford and see if that solves the issue.
Old Dec 5, 2021 | 05:42 PM
jake415's Avatar
jake415
At $60 I will bet it was a knock-off. Sorry this happened, so frustrating! I paid $110 or so approx 2 years ago from Fairway Ford in Ohio. Just have your VIN handy when placing your next order. Good luck!
Old Dec 6, 2021 | 07:30 AM
99powerstrokedF250
I always check out the seller when I'm buying Ford electronics off Amazon. If it's coming from a Ford dealer (and you can tell) then it's a legit part, if it isn't then I don't buy it. 90% of the time I buy it direct from my local dealer anyway, but if they don't have it in stock I'll check other methods.
That said, I think my dealer charged $150 installed for the TBC on my wife's 2019. This was a couple years ago, but everything works correctly so I'm quite happy with it.
Old Jun 10, 2024 | 01:59 PM
exploringcarolina's Avatar
exploringcarolina
6th Gear
deleted post
Spoojr
2015 - 2020 F150
Dec 2, 2021 10:30 AM
fluidp
2015 - 2020 F150
Aug 17, 2020 10:07 PM
MustangMatt96GT
Dec 17, 2008 08:31 PM
Vipersix
All Things Towing
Jul 5, 2004 06:03 PM
fordnut74
All Things Towing
Dec 25, 2003 03:58 PM
