Ignition wire Killer?
Old Dec 1, 2021 | 03:45 PM
catattak20's Avatar
catattak20
I have a 78 F250, 6.6 that has run dutifully for years and years (it has never been out of the family)
and the other day it quit running and wouldn't restart, and the motor seemed to be free spinning.
After some testing, I found that the lead ignition wire did not have continuity, so I bought a new set of wires since you can't buy just the lead wire.
After testing the new lead wire and confirming it had continuity, I put it on. it kind of started for a second and then started free spinning and spitting fuel up and out of the carburetor (I had the air cleaner off). I took the new ignition wire to the bench and now it has no continuity.
I have Googled and searched this site for reasons that would kill ignition wires, but came up empty.....anyone encounter this before?
Old Dec 1, 2021 | 04:37 PM
Dan E. Boyd's Avatar
Dan E. Boyd
Are you meaning the #1 spark plug wire?
Old Dec 1, 2021 | 09:48 PM
catattak20's Avatar
catattak20
ignition wire, from coil to distributor. All plug wires are fine
Old Dec 1, 2021 | 10:08 PM
tbear853's Avatar
tbear853
New wire? Ends intact still? Resistor or solid core? Sounds like it was damaged as it was installed if it checked good before install.
Old Dec 2, 2021 | 11:31 AM
dustyroad's Avatar
dustyroad
If it's puking fuel up thru the carb, that is an issue on it's own. It should never do that.
My 4350 did that and the float was stuck. If the coil wire is burning out, I'd check the coil and make sure it's ok.
bad plug wires will not cause fuel to puke up from the carb.
whitetop
Aug 29, 2021 11:24 AM
Billy Bee
Jan 17, 2021 07:05 PM
youngone1234
13
May 1, 2016 04:11 PM
wesayso
1997 - 2003 F150
Sep 4, 2006 03:19 PM
pknute
Jan 29, 2006 01:55 PM
