What is up with finding a horn pin for the 75 F-250?
I think I'm moving two steps forward them one back. I'm starting to understand why the PO did three things they did.
My year must cross over with the bronco or another year.
Summit has some after market I could try.
If you have some different sites I would love to check them out.
Thanks
Auto Krafters has some on pg 27 and pg 108 of the newest cartalog, but they call them "horn brush contact" ... but they only list 1961 up to 1972. Don't know if adaptable but numbers are C0AF-13A821A and C2OZ-13A821A ... probably have pics on line.
You mean the piece with the contact plates? 65-77 Bronco steering wheel center piece will probably not work because it is probably to small? 78/79 Bronco steering wheel center is different and the horn pad (is to big) so it will not work in a 73-mid 77 steering wheel. I have a 76 parts truck and I might have the center piece.
