Sponsored by: Auxito
Ignition Wire Changeout
Old Sep 3, 2006 | 07:32 PM
wesayso's Avatar
wesayso
I changed the ignition wires and the plugs out on my truck. I now have a skip or misfire at times, but not all the time. I have checked the plugs for cracking and checked the boots for tightness. They appear to be ok. Seems I remember something about the wires crossing over one another?? Any other ideas? Please help! Thanks.
Old Sep 3, 2006 | 07:39 PM
LxMan1's Avatar
LxMan1
Did you put them back in the wire holders like they were originally? Did you use dielectric grease on the plug boots?
Old Sep 3, 2006 | 09:25 PM
wesayso's Avatar
wesayso
As far as the wire holders, I am sure they are probably not back in there as they were. Does it matter if they cross one another ?
Old Sep 3, 2006 | 09:46 PM
LxMan1's Avatar
LxMan1
It can, what brand of wire did you use?
Old Sep 4, 2006 | 10:14 AM
wesayso's Avatar
wesayso
I used autolite brand which was the best brand Auto Zone kept in stock. They had a cheaper China brand I avoided.
Old Sep 4, 2006 | 10:57 AM
LxMan1's Avatar
LxMan1
Has it given any codes yet? Is it possible that you may have knocked a vacuum line loose somewhere during the install?
Old Sep 4, 2006 | 03:19 PM
wesayso's Avatar
wesayso
I went to the store and bought some plug spacer wires and had the code read. It indicated No. 6. I pulled the plugs to inspect them and found the No. 6 to have a cracked insulator. I had done this once but must have missed it. It is now purring like a kitten. Also put in about twice the spacers as originial!! Thanks for your help.
