6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
egr replacement
Old Nov 29, 2021 | 07:06 AM
jralls5321's Avatar
jralls5321
egr replacement
I have a 2008 6.4 with coolant flowing through the egr valve.the new replacement has no ports.Where do i connect the coolant line?
Old Nov 29, 2021 | 09:21 AM
Rudiak's Avatar
Rudiak
You can just plug it or Delete the EGR SYSTEM before it kills your engine.
Old Nov 29, 2021 | 10:42 AM
Fefanatic's Avatar
Fefanatic
It sounds like you have the wrong egr valve. Double check your part.
Old Nov 29, 2021 | 02:35 PM
Rudiak's Avatar
Rudiak
The updated design does not require the coolant line.
Old Nov 30, 2021 | 06:52 AM
jralls5321's Avatar
jralls5321
Entering collant lone and exit line.
Thanks RUDIAK.I'm stil wondering about the ports on the vertical cooler which has two ports.Any suggestions?
Old Nov 30, 2021 | 02:58 PM
jralls5321's Avatar
jralls5321
Thanks for your comment.This egr replaces the one with collant going through it.The flow through is not avaliable or at least i can't find one.My concern is where does the outlet hose go.
Old Dec 2, 2021 | 09:11 AM
Fefanatic's Avatar
Fefanatic
Originally Posted by jralls5321
Thanks for your comment. This egr replaces the one with collant going through it.The flow through is not avaliable or at least i can't find one.My concern is where does the outlet hose go.
If this is a direct replacement without any cooler nubs then get a short piece of pipe and clamp the two cooler lines together so coolant will flow through them. I didn't realize the new egr's didn't allow for cooling anymore.
Brad Wissinger
Oct 23, 2016 05:38 PM
Dave Dirsa
Jan 11, 2016 07:53 PM
chaser1602
Aug 7, 2014 06:48 PM
DavidMcC
Dec 28, 2010 07:07 PM
mopnup
Jun 21, 2008 12:00 PM
