EGR vs EGR delete
Old Dec 28, 2010 | 06:45 AM
DavidMcC's Avatar
DavidMcC
EGR vs EGR delete
Hey y'all I have a coolant leak coming from my EGR coolant line I was wondering about it and I have two options I could just replace the line or buy the EGR delete kit for it I don't know too much about the delete but I wanted to ask y'all before I do anything
Old Dec 28, 2010 | 06:56 AM
06silvercrew's Avatar
06silvercrew
Its one of those deals where it comes down on how much you want to spend and if you can do it yourself. If time and money is a factor and all your vital signs look good, replace the hose. If you have the time and money, go for a delete or a bulletproof egr cooler, and while you are in there I would HIGHLY recomend a new oil cooler and a few other misc items so you wont have to go back into her. But all this could get into the $500-$1000 range depending on which route you go and if you do it yourself.
Old Dec 28, 2010 | 07:09 AM
DavidMcC's Avatar
DavidMcC
It's for a 6.0L turbo diesel
Old Dec 28, 2010 | 08:54 AM
gearloose1's Avatar
gearloose1
Coolant filter, Oil, EGR cooler (I would go OEM Ford), and also clean carbon, diagnose root cause of issue.
Is EGR valve working properly?
Old Dec 28, 2010 | 10:35 AM
gearloose1's Avatar
gearloose1
Check these links out:
https://www.ford-trucks.com/forums/1...gr-cooler.html
Old Dec 28, 2010 | 10:44 AM
cartmanea's Avatar
cartmanea
Is it just the little 2" long hose piece that connects the cooler to the intake coolant lines? That piece is replaceable and pretty cheap.
Old Dec 28, 2010 | 04:23 PM
powerstroke72's Avatar
powerstroke72
Moved to 6.0L Power Stroke Diesel forum.
Old Dec 28, 2010 | 07:07 PM
wulfman's Avatar
wulfman
CARTMANEA that little hose is like 53 bucks, bought one while back.
05 f250 6 inch lift
Jun 3, 2014 04:54 PM
USCG_PA
Mar 2, 2014 01:58 PM
sglass57
6.4L Power Stroke Diesel
13
May 1, 2013 07:33 PM
Onefast96svt
Apr 27, 2013 06:08 PM
DFLS
Dec 1, 2009 08:06 PM
