Coolant flow ???
Old Aug 7, 2014 | 03:25 PM
chaser1602's Avatar
chaser1602
Coolant flow ???
Looking at the degas bottle the small line on the left is the egr return. What is the one on the right? If an egr block off is installed does the coolant still flow to the degas bottle????
Old Aug 7, 2014 | 04:11 PM
f250rangerexplorer's Avatar
f250rangerexplorer
i would think it would have to because when you do an egr delete the coolant still has to flow to the oil cooler first then after the oil cooler it would head to the egr cooler. Hence every egr delete you see has a coolant tube and hose.
Old Aug 7, 2014 | 04:55 PM
npccpartsman's Avatar
npccpartsman
You don't want to block the flow from that small line to the degas bottle. It actually carries a lot of bubble vapor to the tank. I had a clear gas filter in that line and when it stopped up my truck puked like a drunk school girl.
Old Aug 7, 2014 | 06:09 PM
merc82's Avatar
merc82
Yes.. Coolant still flows through the egr portion of the intake even though egr portion is blocked off.
Old Aug 7, 2014 | 06:43 PM
chaser1602's Avatar
chaser1602
OK Thanks. What about the nose on the right?
Old Aug 7, 2014 | 06:48 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
It's the radiator overflow hose
Luke Langlois
Oct 8, 2017 01:50 PM
Byron Rouzer
Feb 7, 2016 03:48 PM
dillehay
Aug 28, 2010 02:27 AM
sawtooth
6.4L Power Stroke Diesel
Oct 12, 2009 10:48 AM
david11690
May 21, 2006 07:30 PM
