Below is a link to a full write-up of how @ZachT93 accomplished the ESOF rocker switch modification. Link included for future reference and search results.
When you take out the Air Intake Heater relay, what needs done with all the extra wires?
I understand what logic must be done to activate the relay from the truck's computer, since I never use the parking brake the computer should never try to turn on the relay and no codes would be thrown. So, what should be done with the extra wires? I get that one of the wires needs a resistor wired in, just to make sure the DTC is never thrown, and that a ground can be eliminated. But what should, or can, be done with the supply power wire? Has anyone eliminated it entirely from the harness?
I removed the wires from AIH to relay and ground but left the supply wire going to the relay in place. I didn’t see an easy way to remove without causing a loose hot wire needing taped up so figured the relay was a safe ending point.
Sorry, can’t help you on the resistor side of things. It just throws a soft code on my truck so I don’t worry about it.
I was looking at the body builder's guide for information about the Aux. Idle Control plug that @aawlberninf350 mentioned, and I saw two of the wires are a CAN + and CAN - line. Does anybody know if there is information available about Ford's CAN system on our trucks?
So purchased this relay box / fuse holder for the truck. I'm going to use it to do the headlight upgrade that was recommended.
It included 6 relays, 6 fuses, and all the roll crimp connectors for $30; I think I got a good deal out of the buy.
I will use one of the relay slots for the 2Lo mod that Sous has described in a separate post. Then the other three relays will be available for future upgrades.
