Back up alarm
Old Dec 26, 2021 | 06:47 PM
Bearhugger1933's Avatar
Bearhugger1933
Back up alarm
2001 f250 ,did it come from factory with back up sensors or was it added later.thanks
Old Dec 26, 2021 | 07:14 PM
bigb56's Avatar
bigb56
Good question. My window sticker shows Parking Aid (reverse vehicle aid sensor) as an option so I assume it got shipped from the factory already installed. It would be tough to install after the fact unless you had a special punch to punch the holes in the bumper which If I recall are not perfectly round. The module is up in the passenger footwell so there would need to be a connector there if you were to add it, as well as a connector at the push button over ride switch on the dash.
Old Dec 27, 2021 | 11:04 AM
Bearhugger1933
Thanks mine is a2001 and it has them,I messed up my bumper and I was wondering if it was put on later,but it looks likes it came from the factory with them.Thanks
Old Dec 27, 2021 | 11:18 AM
bigb56's Avatar
bigb56
I bent my bumper too and it made one of the sensors go crazy. I was able to remove the bumper and straighten it with a chunk of 2X4 and a BFH. Everything works normal now.
Old Dec 27, 2021 | 11:28 AM
Bearhugger1933
I bent mine too bad and will have to get another bumper.
Old Jan 6, 2022 | 01:33 AM
alarsen02's Avatar
alarsen02
I just bought a 02 f350 with these sensors and the button on the dash. The button is always lit up saying off and i can get it to shut off but as soon as i put it reverse it says its off? My 01 that i wrecked did not have this feature so i'm not 100% how it should work. thanks
Old Jan 6, 2022 | 09:15 AM
bigb56's Avatar
bigb56
It might be the module which is located in the passenger side footwell behind the right side panel. Mine had got wet and the system wouldn't work. If you have AutoEnginuity you can trouble shoot with that.
Old Jan 6, 2022 | 02:42 PM
alarsen02's Avatar
alarsen02
That was too easy thanks for reminding me I have AE. It shows a C1707 and C1704 both are sensor faults. Thanks for the tip
yomadmike
17
Aug 15, 2011 12:36 PM
91 blowncoupe
Nov 26, 2007 10:56 PM
samoy
2004 - 2008 F150
Jun 25, 2004 07:26 PM
Night Hooter
2004 - 2008 F150
Feb 21, 2004 09:52 PM
Johnny Mo
Feb 6, 2002 11:29 AM
