Window Falling Down
Old Nov 25, 2021 | 12:31 PM
Superduty450's Avatar
Superduty450
Window Falling Down
What causes these Superduty windows to just fall open? It happened while its parked.
Old Nov 25, 2021 | 01:19 PM
my_crib_too's Avatar
my_crib_too
Gravity? .
Bruce
Old Nov 25, 2021 | 01:33 PM
seville009's Avatar
seville009
Just one window?
I think that on some years there was a setting from the key fob that would open up the windows a bit to let the vehicle air out before getting in on hot days. Maybe that is happening if you have that option?
Old Nov 25, 2021 | 03:13 PM
Superduty450
No it was up and the next morning it was all the way down like it is not connected to anything plus it was cold overnight and toe motor runs but nothing happens
Old Nov 26, 2021 | 08:05 AM
Tumbleweed1972's Avatar
Tumbleweed1972
Time to pull of the door panel and have a peak. I was in there but I can't remember exactly how the motor work on these trucks. I think it is an arm with a wheel that run in a track along the bottom edge of the window. maybe the wheel fell off of your arm let the window fall down. All you can do is open it up and diagnose and let us know.
Old Nov 28, 2021 | 09:27 AM
toddb1's Avatar
toddb1
most likely your window regulator fell apart. They are not difficult to replace.
Old Sep 25, 2022 | 03:28 PM
Superduty450
Well since I started this thread I just had my 3rd window regulator failure, parked in my driveway and 2 hrs later the drivers window had fallen open due to regulator failure. The 2nd failure occurred last November in a RV park during the night. Don't leave anything valuable in your truck, very insecure due to part failure.
They may not be difficult to replace but they are over $200 and they are failing due to a cheap piece of plastic breaking.
Old Sep 27, 2022 | 05:18 PM
The Bone's Avatar
The Bone
Where are you getting these parts?
Old Sep 27, 2022 | 08:47 PM
Superduty450
They are OEM
Old Sep 29, 2022 | 09:46 AM
The Bone's Avatar
The Bone
Then I would try www.rockauto.com and see if they have a improved part. I hate that Ford continued to use cheap plastic parts in window regulators. They are not the only ones though. I have replaced regulators before and it not only is a pain but taking the door panel off all the time isn't good for that ether.
Old Sep 29, 2022 | 09:07 PM
Superduty450
I have an extended warranty so it's $100 deductible which is still cheaper, it threw a PO402 code today so they can fix both
HorsePower Junkie
Jul 27, 2021 12:18 PM
rcosta
Feb 3, 2011 09:04 AM
boilrman
13
Jan 15, 2007 05:29 PM
Cameo
1978 - 1996 Big Bronco
May 27, 2003 11:42 PM
