Yikes!! Window stuck in down position!
Old May 26, 2021 | 10:13 AM
HorsePower Junkie's Avatar
HorsePower Junkie
What do I need to check or replace?
Electric windows...
Rolled the window down and it would not go back up.
Old May 26, 2021 | 11:09 AM
Dweber85rc's Avatar
Dweber85rc
I would try grabbing the wire loom that goes to the door from the cab and wiggle it around while working the switch to check for a broken or cracked wire.
Old May 26, 2021 | 07:04 PM
Cocky EX's Avatar
Cocky EX
Dirty switch contacts are a very common issue on fords. Happened to Dads truck, I cleaned the contacts and the button worked by pressing a little harder than normal until the new one arrived. Easy to try.
Old May 27, 2021 | 07:52 AM
BassFantasizer's Avatar
BassFantasizer
Electric windows on most Fords typically wire through the driver's door switch. That one is the cause of failures more often than the switch located closest to the window.
I'd pull the switch panel and test the driver's door switch(es) first. If the switch tests good, test for voltage at the motor.
Old May 27, 2021 | 10:09 AM
wallz's Avatar
wallz
Broken wires in the rubber boot as you open the door. Most common problem.
Old Jun 23, 2021 | 01:02 PM
travs66's Avatar
travs66
Did you happen to lose your radio at the same time? Did the power ever return?
Old Jun 23, 2021 | 01:43 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
Mine did the same thing, contacts went bad in the buttons, ordered the new control on amazon/ebay, and fixed it right up.
Even though it was only 2 of the buttons acting up, i replaced the lock button as well since i was in there already.
Here is the lock button
Amazon Amazon
Here is the mirror
Amazon Amazon
and i found the window controls on lakeland ford.
Old Jun 25, 2021 | 08:31 PM
HorsePower Junkie
MasterX,
Please provide a link to the window switches you used.
The mirror link did not work, came up with error.
The front passenger window did go back up after many attempts. Have not tried to lower it again out of concern it might not go back up.
Mirror control buttons work correctly.
Lock and unlock button works correctly.
All windows go up and down except the front passenger window.
Radio is working.
Thanks to all for your help! 👍
Old Jun 25, 2021 | 10:17 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
WARNING, My truck is a 2000, i know some of the electronics changed in 2002-2005, so if your in that year range verify fitment
Window Switches, this is the exact one i bought, from the invoice emailed to me
https://www.lascoautoparts.com/oem-p...ch-xl1z14529ba
This is the link for the mirror controller, i just tested the link, works for me:
Amazon Amazon
Lock Switch
Amazon Amazon
EDIT: I just saw on your profile you list having an 04 Excursion, triple check your fitment before ordering!!!! GEM made a lot of the electronics inside change at the 2002-2003 point, but not all.
Old Jun 25, 2021 | 10:37 PM
JAck19's Avatar
JAck19
I had a problem with mine performing intermittently as well. The motor was on its way out. Pulled the regulator and swapped in a new motor, and all was well
Old Jun 26, 2021 | 07:45 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
i knew mine was the switches because it was occurring on all windows, and if i wiggled and pressed real hard, almost to the point of breaking the damn thing they would intermittently work. installed the new switches, problem is GONE
Old Jul 27, 2021 | 12:18 PM
crashed_edition's Avatar
crashed_edition
I was having kinda the same issues.... including my AC going in and out.
Ended up being a bad battery connection. The ground on 1 of my batteries was loose and corroded. I only found this after tearing all the dash, doors etc out and troubleshooting.
Don't be like me. Clean and tighten battery cables and vehicle grounds before troubleshooting.
bankerbob
1961 - 1963 F100 Unibody
Nov 3, 2017 08:39 AM
rcosta
Feb 3, 2011 09:04 AM
boilrman
13
Jan 15, 2007 05:29 PM
Cameo
1978 - 1996 Big Bronco
May 27, 2003 11:42 PM
