Collasped hose normal?
Old Sep 27, 2022 | 10:13 AM
acdii's Avatar
acdii
I noticed yesterday when installing the Derringer that my upper radiator hose was collapsed. This is on a cold engine. When running at temp the hose is fine.
Old Sep 27, 2022 | 11:39 AM
Sport45's Avatar
Sport45
Doesn’t sound normal to me. I haven’t looked at my system too close but suspect you have a reservoir cap that’s not opening to prevent vacuum or the hose is kinked that’s supposed to allow coolant back into the system from the reservoir.
Old Sep 27, 2022 | 01:23 PM
colossians3:23's Avatar
colossians3:23
Had this on both 6.7's Ive owned. New coolant reservoir cap will fix it.
Old Sep 27, 2022 | 02:10 PM
brokestroke's Avatar
brokestroke
Have a 2016 6.7 that has always done it, never seemed to effect anything and never thought twice about it. May be worth looking into I suppose.
Old Sep 27, 2022 | 05:12 PM
The Bone's Avatar
The Bone
I saw this on my 15 and changed the cap on the degas bottle and was fine for a couple days then it went back to sucking it closed. I talked to my Ford diesel guy and he said it was normal.
Old Sep 27, 2022 | 08:17 PM
colossians3:23
Normal or common? They dont come like that from the factory...could be a small pressure leak in a coolant fitting or something?
Old Sep 27, 2022 | 09:40 PM
FishOnOne's Avatar
FishOnOne
Common... The issue is typically with the cap. As the cooling system goes thru a heat cycle the air expands and pressure is created and as the cooling system cools the air retracts creating a vacuum. Mine did this a few years back and never created a issue. If it bothers you replace the degass bottle cap.
Old Sep 27, 2022 | 10:21 PM
jollyrogr's Avatar
jollyrogr
Coming from the GM world, a collapsed coolant hose on a duramax is a good sign the head gaskets are blown.
Old Sep 27, 2022 | 10:57 PM
cj45lc's Avatar
cj45lc
On one of A Rod's videos on youtube he commented on the collapsed hose saying something like congrats you have a nicely sealed cooling system. Mine has done this as long as I've had it so I thought it was normal.
Old Sep 28, 2022 | 08:10 AM
The Bone's Avatar
The Bone
It would appear that all of these trucks do this. I replaced my cap and it went back to a collapsed hose anyway.
Old Sep 28, 2022 | 10:45 AM
acdii's Avatar
acdii
Good to know. I thought it was odd, but looking at the length of hose and that there is no spring inside to prevent collapse since it is a return hose, I figured I would ask. I had to pop a small hose off the degas to run the harness for the Derringer and it sucked in air restoring the hose. Does sound like the vent in the cap isn't working. I also need to look into the coolant, I thought it is supposed to be yellow coolant, but I think it is green.
Old Sep 28, 2022 | 10:51 AM
Overkill2's Avatar
Overkill2
https://www.ford-trucks.com/articles...ellow-coolant/
Old Sep 29, 2022 | 09:28 PM
machmedic's Avatar
machmedic
My 2019 F450 did this also for the 2 and a half years I had it. Never was a problem.
Pete Kildow
Large Truck
Nov 5, 2013 10:19 PM
teamlx88
Aug 2, 2010 10:48 AM
buggaboo
Nov 1, 2008 11:13 PM
Jokenring
Jan 6, 2006 09:06 PM
Aeropain
Aerostar
Sep 21, 2004 04:35 PM
